Old 01-21-2006, 06:12 PM   #1
tdm850rider
tdm850rider is on a distinguished road
tdm850rider's Avatar
2002 SL1
Default service engine soon light, idle a bit rough
Got a problem someone may have had experience with.
Two tanks of gas ago I filled up with a different brand, added fuel injector cleaner to the tank... SES light came on, but I expected that as the engine would be running a little rough while the FI cleaner ran thru... 160 miles after fill up the SES went off. Now about 100 or so miles later I filled up again and as it was a nice day ran it thru a carwash... SES light came on again for 62 miles.
OK... there were possible reasons for both of these, the fuel change/FI cleaner and the carwash (electrical may have gotten damp). But a few days ago the SES came on yet again and the engine still does not feeel as smooth as it had been.
'02 SL1 (bought used in Nov with 30k) miles are 33/34k now. The SES wouldn't be coming on to prompt me to get the regular 35k service would it?
Hints appreciated.
Tom (Pgh, PA)
'I can resist everything except temptation'
Thomas....
tdm850rider is offline   Reply With Quote
Old 01-21-2006, 06:25 PM   #2
sunshn1972
sunshn1972 is on a distinguished road
sunshn1972's Avatar
Default Re: service engine soon light, idle a bit rough
If the SES ligth is coming on then there are some codes stored. Get them read and let us know what they are. We can't say much without them.
This space intentionally left blank.
sunshn1972 is offline   Reply With Quote
Old 01-21-2006, 06:28 PM   #3
Razorbak
Razorbak's Avatar
Diagnostic trouble codes can be read for free at a lot of auto parts stores (e.g., AutoZone).
Razorbak is offline   Reply With Quote
Old 01-21-2006, 06:43 PM   #4
tdm850rider
2002 SL1
Now THAT's good to know. I'll do that monday, should be in here by tuesday.
Thomas....
Old 01-23-2006, 05:46 PM   #5
tdm850rider
2002 SL1
Thumbs Up Re: service engine soon light, idle a bit rough
Trouble code:
P0301
Cylinder 1
Misfire Detected
Well, that explains the intermittent 'roughness'.
I suppose a tune-up would sort everything out. I already have an appointment for wednesday afternoon. New plugs, wires, and fuel filter.
Thanks for the info about the free code-reading, I always like to hear 'free', it's my favorite 4-letter word.
Thomas....
Old 01-23-2006, 07:24 PM   #6
Thor4SL2
Thor4SL2 is on a distinguished road
Thor4SL2's Avatar
Free is your favorite word and you are paying someone to do that work. I'll bet the labor bill will be close to $100.00 Changing the plugs and wires on an SL is about a 15 min. job. The only “special” tools you need are a spark plug socket and a wire type gap gauge (0.040 size). If you are a profectionist add a torque wrench (20 ft-lbs.) to tighten the plugs.
OK, the fuel filter is a bit of a pain in the arse, but is still in the realm of the driveway mechanic.
It's not what you know that counts,
it's what you think of in time!
Thor4SL2 is offline   Reply With Quote
Old 01-23-2006, 10:41 PM   #7
arfalberg
arfalberg is on a distinguished road
I agree most of the tune up stuff is very simple, a simple $20 tool kit from Wal-Mart should have most all the tools you need to do the jobs in your driveway, add a sparkplug gapper and you are in buisness.
arfalberg is offline   Reply With Quote
Old 01-23-2006, 11:03 PM   #8
dansl2
dansl2 is on a distinguished road
dansl2's Avatar
2000 SL2
That fuel filter for your car will run you approx $60+ through saturnparts.net as it contains the fuel regulator also. Pretty easy to do & will save you probably another $75+ in labor. And you probably don't need to change it yet anyway.
Experience is something you don't get until just after you need it.
dansl2 is offline   Reply With Quote
Old 01-24-2006, 08:57 AM   #9
sunshn1972
sunshn1972's Avatar
I definitely wouldn't say that the fuel filter/regulator is easy to change. I did it on my 98 SL2. In my experience and from what I've read, it's very common for the two bolts holding the retaining clip to the vehicle to break when trying to get them out. They're small aluminum bolts, and get badly rusted in place because the filter/regulator only gets changed every 100,000 miles. I ended up tapping larger holes and using grade 8 bolts so I should have better luck next time. Mine filter/regulator cost $80.53 at saturnparts.com. There is at least one thread with pictures in the how-to section on how to change this if you want to do it yourself.
If you're only at 34,000 miles, I'd seriously question replacig the filter/regulator since it's scheduled to be replaced at 100,000 miles. For me, it's too expensive to replace at 34,000 without being sure it's bad.
Old 01-24-2006, 01:57 PM   #10
JS593
JS593 is on a distinguished road
JS593's Avatar
1992 SL1
24.99 from Canadian tire. and thats CDN value.
92 SL1 SOHC TBI
Custom intake
Alpine deck, speakers, amp
JBL Sub
Ultimate amp
Volometer gauge mounted in dash
Magnaflow exhaust
....DEAD.... Car towed away Jan 18 2007. RIP
JS593 is offline   Reply With Quote
Old 01-24-2006, 02:22 PM   #11
BarnOwl
BarnOwl's Avatar
Not on a 2002. I'm not sure whether it's 1999 or 2000, but somewhere in there the fuel filter and fuel pressure regulator became part of the same assembly and it's significantly more expensive.
Old 01-24-2006, 05:55 PM   #12
brenspin
brenspin is on a distinguished road
1998 SW2
My 1998 also requires this newer more expensive filter. I think 1998 was the first year.
The part is $80 on that saturnparts website.
brenspin is offline   Reply With Quote
Old 01-24-2006, 09:40 PM   #13
tdm850rider
2002 SL1
Dizzy Re: service engine soon light, idle a bit rough
I thought that would get some response!
I would put new plugs in first and see if the misfire went away, second step would be new wires...
didn't know the filter was good for 100k so forget that.
Now if the misfire is still there after new plugs and wires, what could be the most likely culprit?
Injector nozzle feeding cylinder 1?
I would be doing it myself if I wasn't outside in a 15 degree windchill.
Maybe I can borrow the use of someone's garage?
(I HATE the cold.)
Thomas....
Old 01-24-2006, 09:48 PM   #14
techguy
techguy is on a distinguished road
Hey,I noticed that you said that there was code p0301 cylinder miss fire on #1 the sohc engines around that year have a problem with the intake gaskets leaking for #1 cylinder at the head. that is most likly your problem you need anew intake gasket.
techguy is offline   Reply With Quote
Old 01-24-2006, 09:52 PM   #15
dansl2
dansl2's Avatar
2000 SL2
(I HATE the cold.)
Before you go after the injectors, try cleaning the coil towers with a fine grade sandpaper. You might want to do the job right & remove the packs & DIS, give those a good cleaning to ensure good contacts . There is an excellent "how to" by Wolfman (with pictures) in the...you guessed it..."how to library".
Old 01-24-2006, 09:52 PM   #16
tdm850rider
2002 SL1
If the problem was across a model year or more... Would there be a service bulletin? (Not sure if that's the right word). Any 'recall', 'saturn will fix their mistake', 'we will fix it free/reduced' type of thing?
Thomas....
Old 01-24-2006, 09:54 PM   #17
tdm850rider
2002 SL1
It would have to be excellent as I have no idea what coil towers, packs, and DIS's even are.
Thomas....
Old 01-25-2006, 02:58 PM   #18
techguy
That year does not normaly have a problem with coils or wires but go a head and check them. I really believe that your problem is your intake manifold gasket, leaking on #1 cylinder you can use some carb cleaner to spray around the manifold while the engine is running to see if your rpm changes at all which would indicate a vac. leak . But be careful not use to much around a hot engine.
Old 01-25-2006, 04:51 PM   #19
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
(I HATE the cold.)
It's gonna be 48 degrees in pittsburg on sat.
But you can use my garage if you want (bout 300 mile drive, however)
Old 01-25-2006, 05:35 PM   #20
mscougargirl
mscougargirl is on a distinguished road
mscougargirl's Avatar
2002 SL1
I just had an intake gasket replacement. Car ran like absolute garbage before the replacement. Rough idle, SES light on, just horrible. Now it runs like a champ. By the way when you're doing the tune up be sure to get a new air filter installed. Nothing is worse for fuel consumption and performance than a car that can't breathe!
mscougargirl is offline   Reply With Quote
Rough IDLE/Low IDLE no check engine light savage21 Vue Tech 9 12-08-2010 01:27 AM
Rough Idle, Blinking Engine Light RySci Ion Tech 15 01-13-2009 12:17 AM
Service Engine Light - rough acceleration MattGahan Vue Tech 4 12-14-2008 02:46 PM
2002 L 100 service engine light and rough idle oscar5150 L-Series Tech 5 10-24-2006 10:57 PM
Ignition Module / Engine Coolant Sensor Prob? Service Engine Light, Rough Performins Brendo613 S-Series Tech 14 10-19-2005 07:12 AM
