Old 03-14-2008, 12:21 AM   #1
Ackpacket
Ackpacket is on a distinguished road
Default A lesson in transaxles
Hey all, long time reader first time poster. First let me just say how much I love my '02 sl2, it responds cheerfully to the least bit of love you give it.
Alas, my transaxle(automatic) is failing (or so i've been told... by aamco). They wanted to charge me 1095 in labor to take it off and put it back on, who knows what the parts would've cost. They said 2500 at most for everything, complete overhaul.
So, what are my options basically?
Where is a good place to find another transmission?
How can I find out which transmissions will fit my car?
Where can I learn to rebuild the transmission myself? I'm pretty mechanically inclined, and more than likely have all of the tools necessary. My dad was a professional mechanic for 35 years, and when he passed away I inherited that lifetime collection of tools. I have no transmission experience so i'm wondering where I can get some very thorough reading material, hopefully specific to my transmission as opposed to those general haynes manuals. I would really love to rebuild it myself as opposed to putting a different one in, I love experiences like that.
Thanks in advance for any advice you can offer!
P.S. Some important info:
123k miles
last transmission service: unknown. Only have had the car for 1.5 years, it was also inherited from my dad.
Specific symptoms: Bucks very hard when shifting into third gear. Getting slightly worse, problem has began to slightly cover other gears. It gets worse with cold and better with heat. Filter was just changed when a friend mistook it for the oil filter. Unfortunately only a cheap Fram filter was put on.
Ackpacket is offline   Reply With Quote
Old 03-14-2008, 06:56 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: A lesson in transaxles
First off the fluid and filter needs to be changed every 30K and you should have done it when you got the car. If you're really lucky, yours will respond to just a change. You might want to put some Sea Foam Trans Tune in there a couple days before the change.
Rebuilding a transaxle is beyond the skills of most of us. However, you probably can get by with a valve body. Aamco is irratic at best when it comes to making the proper diagnosis. They just say rebuild. There's one brand of valve body, Transtar I think, that seems to get a lot of bad reviews. Look in the How-To Library for valve body and you'll find some instructions. You can do it without removing the transaxle.
Old 03-14-2008, 08:04 AM   #3
Uzzy
Uzzy's Avatar
2002 SC1
Never ever ever ever trust Aamco. It seems like no matter where you are, the Aamco is crooked.
Aut viam inveniam aut faciam
Old 03-14-2008, 08:43 AM   #4
white-sl2
white-sl2 is on a distinguished road
your first reply my second. I assume you've checked the fluid, I might have missed it in your post who knows, anyways I second the fluid change. Dont think a cheap filter matters. I replaced my auto trans fluid about 110,000 for the very first time and it was black as night, put some new fluid and a cheap filter and it works fine. And when you take it to a place like Aamco, its always broke. Thats how they make their money.
white-sl2 is offline   Reply With Quote
Old 03-14-2008, 12:36 PM   #5
ExMiata
ExMiata is on a distinguished road
My 2001 SC2 is at a Relco shop now. My neighbor had his van towed(rollback) to the shop, trans rebuilt and returned with a one year warranty for $900.
I got a third party warranty on my SC2 when I got it in January - something I NEVER do. So, if they pay, it will be worth the cost of the warranty.
ExMiata is offline   Reply With Quote
Old 03-14-2008, 12:46 PM   #6
rc1488
rc1488's Avatar
Start off with new fluid and filter. From there if the problem persists, try the seafoam as Barnowl suggester and also try Wolfmans reverse slam remedy.
After those with no success, the next step would be to put a new imput shaft nut on, and then finally a new valve body. Hopefully you dont get this far as it gets more expensive
Old 03-14-2008, 12:51 PM   #7
ringed1
ringed1 is on a distinguished road
1994 SC2
Here's how it works with the less honest Aamco shops: they give you a definite labor estimate for pulling and re-installing the trans (theirs seems high, BTW). As for what's wrong, that's the variable. Once the trans is out and disassembled, that's when they really have a customer over a barrel. Whatever estimate on repair was given usually goes up. Don't like the new quote? Just fine...a customer can pay them for their labor and have the disassembled tranny and the car towed from the shop.
ringed1 is offline   Reply With Quote
Old 03-14-2008, 12:52 PM   #8
sl_don
sl_don is on a distinguished road
sl_don's Avatar
2004 VUE 3.5L
Try the fluid change and if that doesn't fix it then i would look for a used transmission from a similar year wrecked car. i do not trust rebuilt transmissions it is rarly done right and they don't generaly last.
you could do it yourself if you are patient, meticulous and have the factory service manual. the secret to successfully rebuilding an automatic transmission is following the procedures to the letter. they are very sensitive to clearances and tolerances so a good set of quality measuring devices (calipers feeler guages and so on) is a must.
Places like Ammco just bu the wear items and through the transmission back together. sometimes they last 100k miles and other times they don't make it out of the lot.
If it isn't broken.........Your not trying hard enough
2002 SL first brand new car in my family since the 1981 Pontiac Phoenix (sold)
2004 Vue AWD V6 bought used (current)
sl_don is offline   Reply With Quote
Old 03-14-2008, 07:13 PM   #9
Ackpacket
Thank you all for your replies. Very helpful stuff! I knew I'd find what I was looking for here. I have a few more questions:
So, assuming nothing works, where do I look for another transmission? I have no idea.
Also, my trans fluid seems to have a tiny bubble or two in it when I check it on the dipstick. And the level is really hard to guage.
Now, all of you are suggesting a fluid change. There is a drainplug for that. If i take the fluid out through there, will this include the fluid from the torque converter or will I be mixing new fluid with old?
Should I try some synthetic if I do change the fluid?
What's the difference between a fluid change and a flush?
Thanks again for all of the answers! I love my saturn.
-Steven
Old 03-14-2008, 07:45 PM   #10
tacinc1
tacinc1 is on a distinguished road
I've been on this site for about a month. BarnOwl is an expert in this area
and has dedicated alot of his time and knowledge. You would be well advised to follow his thoughts. I purchased my VB from Valvebody Pros. They have been excellent with their support. If you do the valve body, it may be a
good idea to rent an impact wrench for the input shaft nut and torque the
nut on beyond the 111 ft. lbs. Well beyond. As I understand, the over
torque can't hurt and may save you from having to redo the INS.
tacinc1 is offline   Reply With Quote
Old 03-16-2008, 03:48 AM   #11
Red Sc2
Red Sc2 is on a distinguished road
Red Sc2's Avatar
I recently purchased (then sold) a '95 sl2 automatic.... Needed a new tranny since I bought it. When I bought it, it only had between one and two gears.... I went to the junkyard and bought one there for $250 with a 9o-day warranty... Had my mechanic take out the old tranny, and put in the new one, as well as service it for $250.... Grand total = $500 for a used tranny and installation...... If worst comes to worst, go that route
As far as which years are compatible.... Im thinking any OBDII tranny will go but dont quote me- I dont know much about the tranny area- especially autos.... But either way, I would go with 2001-2002 since your car is 2002, the newer the tranny, the better the condition most likely! ESPECIALLY WITH SATURN AUTOMATICS....
Shoot, while your at it, you might as well drill a couple of holes in the firewall and just replace the one you have now for a 5-speed
Red Sc2 is offline   Reply With Quote
Old 03-16-2008, 07:24 AM   #12
Uzzy
Uzzy's Avatar
2002 SC1
In '98 they changed the gear ratios, so anything before that won't work. They also went to the adaptable programming, in that year, I think. Any 5-speed would work with the right PCM.
Old 03-16-2008, 09:25 AM   #13
fredsfix
fredsfix is on a distinguished road
fredsfix's Avatar
1999 SL1
1997 SL1
I can't help but think that a 35 year veteran mechanic had a trans fluid change on occation. What makes me nervous is the idea that you had someone else (who evidendly was clueless) change the oil and you're considering rebuilding the transmission. Am I to assume that the cheap Fram oil filter is still on the transmission? Ever think that might cause a problem seeing how a transmission filter costs three times more than the Fram oil filter?
Barnowl has it right - start with an immediate fluid and correct filter change!
After that investment of about $20 you should notice an improvement with a little driving.
OMG - WHAT YOU SAID !!!
I BET THERE IS 5-30 WEIGHT IN YOUR TRANSMISSION. YOUR BUD DRAINED AND CHANGED THE WRONG SIDE OF THE ENGINE COMPARTMENT!!
You can't call yourself a mechanic if you're surprised it runs!
fredsfix is offline   Reply With Quote
Old 03-16-2008, 10:47 AM   #14
Uzzy
Uzzy's Avatar
2002 SC1
But nobody's dumb enough to pour engine oil down the tranny dipstick, are they?
Old 03-17-2008, 09:08 AM   #15
fredsfix
fredsfix's Avatar
1999 SL1
1997 SL1
We can't let this slide to the back pages until we get an answer about the color of the "tranny fluid".
Old 03-17-2008, 01:38 PM   #16
BarnOwl
BarnOwl's Avatar
Given the difference in cost, I definitely wouldn't go with synthetic in a transmission I consider doubtful. Actually, I don't run synthetic in my transaxles anyway. I install tranny coolers and change the fluid every 15K instead.
DO NOT HAVE YOUR TRANSMISSION FLUSHED!!! This used to be recommended and a lot of shops still do it but, in my experience, it tends to stir up a lot of junk that was better off left where it was. I know a guy at work I told to change his fluid when he got an S-series. He didn't know any better and got a flush. Now, he can hear a solenoid buzzing in the valve body. Changing the fluid you get by draining it, is recommended. You won't get it all but, you'll get enough.
Old 03-17-2008, 04:32 PM   #17
SonnyD
SonnyD is on a distinguished road
SonnyD's Avatar
1999 SC1
You and I both know the answer to that
Regards Sonny
I LOVE MY SATURN!!!!
99 SC1 "Marvin"
2007 Harley FLHX "Street Glide"
Fender 50's Strat...The Guitar That Put the "Rock" in Rock&Roll
SonnyD is offline   Reply With Quote
Old 03-17-2008, 05:07 PM   #18
Uzzy
Uzzy's Avatar
2002 SC1
Regards Sonny
Yes, but it shouldn't be possible.
Hey, post #9000 That's a lot.
Old 03-17-2008, 07:08 PM   #19
rc1488
rc1488's Avatar
Another grand and youll be the 4th Super member
Old 03-17-2008, 09:05 PM   #20
amazinghl
My turbo dodge transmission calls for engine oil...
00 Insight 72mpg
so i've learned my lesson... ion skater6912 Ion General 27 02-18-2012 12:40 AM
A well learned lesson... kickarse S-Series General 7 03-12-2006 12:47 PM
Lesson Learned SW1philly S-Series Tech 3 04-27-2005 10:35 AM
Hub Lesson: ReZDoG Miscellaneous Tech 2 04-12-2004 09:30 PM
A lesson in humility. MyL300 General Saturn Discussion 14 08-02-2003 01:25 PM
