Old 03-07-2008, 06:38 PM   #1
tacinc1
tacinc1 is on a distinguished road
Default Front broke lug nut stud- Do not do's...
I broke a front wheel lug nut stud trying to remove the tire and could not
get the stud all the way out at any of the 360 degree positions. So, I
removed the axle nut and tried to tilt the hub for clearance to no avail.
Crap. I removed the brake caliper and realized that now I could remove
the broke stud and replaced it. So, just remove the caliper. Reminds me
of the saying, "Don't die stupid."
tacinc1 is offline   Reply With Quote
Old 10-18-2010, 11:04 AM   #2
Ghill_Sl1
Ghill_Sl1 is on a distinguished road
Dizzy Re: Front broke lug nut stud- Do not do's...
Glad to read that you were able to get the job done even if you ended up doing all that extra work.
I am currently stressing as I have tried to replace my lug stud a few times but have not been successful. For me removing the brake caliper and the rotor on my sl1 does not give me any clearance to insert a luge stud. Is this all you are supposed to have to do because to me it seems as if you need to remove everything but the axle in order to get clearance?
I am quite frustrated and would love some input if you have had success.
Thanks!
Ghill_Sl1 is offline   Reply With Quote
Old 10-18-2010, 11:32 AM   #3
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: Front broke lug nut stud- Do not do's...
I've never had to remove the caliper to remove the studs. In fact we put longer studs on our old drag car and didnt have to remove the calipers.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 10-18-2010, 05:53 PM   #4
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
I've always had to remove the brake caliper to get a broken stud out.
Try tapping the new one in with a small ball peen hammer. I've found that they don't just drop in, but will go in with a little help.
ShawnV is offline   Reply With Quote
Old 10-18-2010, 06:57 PM   #5
2NDSOUT
2NDSOUT's Avatar
1999 SL
I've had to replace wheel studs on my 94 SL2.
This is how I did mine:
Remove the Brakes, Calipers, and Caliper Bridge
Use a Pipe Wrench or Heavy Duty C-Clamp to secure the wheel hub.
Using a Cold Chisel, tap out the broken wheel studs.
With the Wheel Hub in the C-Clamp, position your first open hole for the new stud at the 1 o'clock position. Gently thread the new wheel stud into place. When it clears the wheel hub and the hub secured with Pipe Wrench/C-Clamp take a Lug Nut to pull the rest of the new wheel stud thru the wheel hub until it is firmly in place/position. Then undo the Lugnut and move onto the next wheel stud replacement, then put all of the brake hardware back in place and position the wheel and attach lugnuts.
Done.
New Wheel studs are $3-$4/piece at your local FLAPS.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 10-19-2010, 10:17 PM   #6
Dr. Sprock
Dr. Sprock will become famous soon enough
or you could chuck up a 3/16 th's drill bit,
go thru most of the way,
chuck up a 3/8 in a milwaukee 1/2 inch jacobs super chuck and you are gone in 60 seconds with the cheap azz steel they use, a little 3o wt on the drill bit so you don't bind,
if you are a Fabricator A, you know how to correct for drill drift,
everybody pushes up and left,
don't forget to vacuum the chips off the living room carpet,
Dr. Sprock is offline   Reply With Quote
Old 10-19-2010, 10:19 PM   #7
Dr. Sprock
double post - mod delete
Old 03-12-2014, 10:49 AM   #8
93wsaturn
93wsaturn is on a distinguished road
93wsaturn's Avatar
1993 SL1
Done.
I just have one quick question about this. It seems that your method of how to install a stud sounds much easier than disassembling the whole steering knuckle. I tried looking at pictures of stock S-Series knuckles and it appears your method will work. My Saturn is a 1993 model year which is only one year previous to yours so I'm assuming the same knuckle was used. I rather install a stud using your method than removing the knuckle. Can you personally guarantee that doing it your way at the 1 o'clock position will allow the stud to slide in rather than removing the hub?
"A Different Kind of Car Company"
-Saturn Generation 1 motto
93wsaturn is offline   Reply With Quote
Old 03-12-2014, 11:15 AM   #9
The knuckle is the same 91-02 the only difference is the number of and diameter of the splined axle hole in the hub. The method you copied works on all years.
Old 03-12-2014, 01:08 PM   #10
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
Geez just get a good hammer, pound the old one out, use an old lug nut and impact to "pull" the new one in and seat it. Done. It takes longer to jack the car off the ground than do the job
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
underthehood is offline   Reply With Quote
Old 03-12-2014, 10:55 PM   #11
billr
I'll give a contrary opinion... any method that involves a big hammer isn't good for bearings. You may get away with it, but don't be surprised if that bearing goes bad prematurely.
Old 03-12-2014, 11:15 PM   #12
+1^^^^You get your choice of stuffed bears on the back top row for the right answer. Do not beat on the hub you will hurt the balls. The broken stud can be forced out and the new one drawn in without hammer action.
Old 03-13-2014, 02:51 AM   #13
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
https://www.youtube.com/watch?v=wAg1r6zw7Bg
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
colonelhogan44 is offline   Reply With Quote
Old 03-13-2014, 07:19 AM   #14
underthehood
2004 VUE 2.2L
Haven't hurt anything yet. 40+ years. In theory maybe correct but, if the hub is good you won't hurt it. And if it's marginal even then only "maybe"
Broken Lug Stud RGZ S-Series General 2 10-03-2008 01:09 PM
95 Sl2 Front lug nut , contact depth . udderslate S-Series Tech 5 04-27-2008 07:49 PM
Broke stud removing lug bolt??? BarnOwl S-Series Tech 3 12-12-2005 09:56 AM
S series lug stud broke off cabo5150 Miscellaneous Tech 8 08-11-2003 09:32 AM
How to replace wheel lug stud? ym42 S-Series Tech 4 07-28-2003 01:47 AM
