Old 03-07-2008, 05:16 PM   #1
tacinc1
tacinc1 is on a distinguished road
Default Get your valve body from Valvebody Pros!!!
I bought two valve bodies that were bad. A waste of time and labor.
I finally did alot of research and found a company called Valvebody Pros
and that were a little more expensive, but well worth the cost because
you know you'll have a correctly rebuilt VB. I found they are a member of
TRANi. Their number is 877-611-7767. If you check your input shaft nut and
it seems tight, replace it anyway or you my be sorry.
tacinc1 is offline   Reply With Quote
Old 03-07-2008, 05:33 PM   #2
Kappa24
Kappa24 is on a distinguished road
Kappa24's Avatar
Default Re: Get your valve body from Valvebody Pros!!!
spam?
'99 XJ Classic w/ a TON of mods...
Kappa24 is offline   Reply With Quote
Old 03-07-2008, 05:52 PM   #3
Valve Body Pro
Valve Body Pro is on a distinguished road
Hey kappa,
Not spam this is true.
Valve Body Pro is offline   Reply With Quote
Old 03-07-2008, 05:54 PM   #4
Kappa24
Kappa24's Avatar
Originally Posted by Valve Body Pro View Post
Hey kappa,
hmmm...just out of curosity...you make a shift kit for a OBD2/96+ Cherokee AW4?
Old 03-07-2008, 05:57 PM   #5
Valve Body Pro
Sorry kappa no shift kit availible at all for that.
Old 03-07-2008, 06:12 PM   #6
Kappa24
Kappa24's Avatar
eh, o well. thanks for looking though. it seems like there isn't any performance parts for that trans at all
Old 03-07-2008, 06:14 PM   #7
Valve Body Pro
Not just yet sorry but we are looking into a few kits we would like to have made up for certain valve bodies. Check out my web page you might be impressed with what we do have
Old 03-07-2008, 06:49 PM   #8
Kappa24
Kappa24's Avatar
interesting, you have the A518/46RH (727 TF) trans listed that I had in my Grand Cherokee. My original trans lasted 224,000 miles behind the V8. I had 33's on it w/ stock gears too. I had it rebuilt HD w/ a shift kit (not sure the brand, came w/ the rebuild), but holy crap did the shift kit make a huge difference!
Old 03-07-2008, 07:01 PM   #9
Valve Body Pro
Kappa its was probably the transgo shift kit. that is the kit we use in most our v.b's. i als do custom and heavy duty valve bodies...
Old 03-08-2008, 05:22 AM   #10
myolbug
myolbug will become famous soon enough
myolbug's Avatar
Two questions fer ya!
My 98 SC2 will surge a little in park or neutral after I have driven it a while. Kind of feels like it is still trying to go. Weird. Any Idears?
Also, my 1990 5.7 Suburban with the L460E has a vibration when driving, and it is in the tranny. Now my question comes with a couple of qulifications. First, the local tranny shops say that it is a out of balance torque converter, and instead of just relplacing the TC, they say to get it rebuilt to the tune of $1900-$2500!
I spoke with a guy I know that has the same vehicle with a deisel engine and he sadi that he used to have the same porblem, but he had the tranny filter replaced and some solenoid upgraded and it took it away.
could this be caused by a valve body that is somehow stuck? Or is there no way of knowing without inspection? I can get a GM new tranny and TC for $1100 if I do the install. This has a 3 yeaar 100,00 mile warranty. The rebuild is only 1 year, but it is supposedly heavy duty.(?)!
If it is OK to disarm law abiding citizens to reduce crime, then it stands to reason to disarm the military to prevent war!
myolbug is offline   Reply With Quote
Old 03-08-2008, 03:24 PM   #11
tacinc1
Do a "SEARCH" on "torque converter stuck" and you will see a post
from Dr. B which has an excellent and easy check to do.
As for your other car, the vibration could be a bad tire, bad u-joint, bad
transmission mount etc. I'd check all these before messing with the tranny.
Old 03-12-2008, 10:37 PM   #12
myolbug
myolbug's Avatar
All checks out. It is tranny related. Though I haven't checked the mounts.
Valve Body Manual Valve Interchange Question acman S-Series Tech 2 11-05-2009 10:40 PM
new valve body motu56 S-Series Tech 5 03-31-2009 03:31 PM
Body kits, the pros and cons of installation Redram S-Series Mods 18 06-03-2006 11:59 PM
Where to get valve body? cubontheridge S-Series General 1 04-25-2006 11:07 AM
valve body bowie1950 S-Series General 1 08-03-2004 11:40 PM
