Old 08-20-2018, 03:53 PM   #1
Medtactics
Medtactics is just really niceMedtactics is just really niceMedtactics is just really niceMedtactics is just really nice
Medtactics's Avatar
1999 SC2
Default No brake loghts
Center and corners won't illuminate with pedal pressed, but all other light functions work, including parking lights.
Bad brake switch? Checked fuses, all good.
If any user helped you, be sure to rep them.
Late 99 SC2 2.5 Gen, 237k miles
"Well... Now my car looks like a blackbarry." - Medtactics, 2017
Medtactics is offline   Reply With Quote
Old 08-20-2018, 04:20 PM   #2
Medtactics
Medtactics's Avatar
1999 SC2
Default Re: No brake loghts
Got 14v to from a brown wire going to the switch, and I believe it is grounded too from the mounting bracket.
Brown does 14v to all wires except orange. And orange wire seems dead.
Old 08-20-2018, 04:28 PM   #3
Medtactics
Medtactics's Avatar
1999 SC2
Update #4 15amp fuse is blowing.
Old 08-20-2018, 05:09 PM   #4
Medtactics
Medtactics's Avatar
1999 SC2
So with tail lights removed and brake switch removed, no short With tail lights and no brake switch, no short.
As soon as I plug the brake switch in, short and a fuse goes pop.
The only thing I haven't tried is a fresh fuse and voltmeter the orange+brown with the brake switch removed. But so far I'm leaning towards brake switch failure after I did a quick run down of the loom and nothing seemed out of place.
If line was dead with bad fuse that should indicate a no short correct?
Old 08-20-2018, 06:08 PM   #5
If wiring is good, and nothing popped the fuse until you worked on the brake light switch (under the dash) and then it began blowing the fuse, replace that switch and then insert a new fuse and it should be good.
Just curious were you using a digital or analog voltmeter to read that 14 vdc and not 12 vdc?
Old 08-20-2018, 06:13 PM   #6
Medtactics
Medtactics's Avatar
1999 SC2
It's a new Battery, so possibly that be, its technically for a light duty Class 6 truck soo...
Let's also hope it goes through for tonight for next day delivery, its gonna be a pain flicking the parking lights on and off.
Part dosen't seem to exist anymore for brick and mortar shops.
Old 08-20-2018, 09:15 PM   #7
Ebay, anywhere from $13 for an off brand to $32 to 40 for the AC Delco.
GM 21020601 (discontinued)
https://www.ebay.com/sch/i.html?_fro...Desc=0&_sop=15
Old 08-22-2018, 05:58 PM   #8
Medtactics
Medtactics's Avatar
1999 SC2
Put in a new fuse checked voltage and it was 15.5v, battery is the same, with the vehicle off.
The new switch popped the fuse.
Ideas?
Old 08-22-2018, 06:07 PM   #9
New switch popped the fuse too?
Just curious, where did you find the correct switch so fast? Locally?
Then, you are left with hunting for a skinned wire touching bare metal.
My suspicion would be where ever the harness is underneath the car body....gotta use a 12v probe light and determine where you do and don't have 12v heading to the back sockets.....might even be a bad socket shorting out.
Old 08-22-2018, 06:16 PM   #10
Medtactics
Medtactics's Avatar
1999 SC2
Ideas?
Orange-brown has voltage
Orange-blue x2 has voltage
Orange-blacks x2 has voltage
So which isn't supposed to be making a connection?
Think I found it, removed both taillights one at a time and the right one gives voltage. Disconnected to orange
Rockauto overnight shipping.
Old 08-22-2018, 06:37 PM   #11
Medtactics
Medtactics's Avatar
1999 SC2
Socket isn't shorting, no voltage to any wires at the socket.
Old 08-22-2018, 07:54 PM   #12
Medtactics
Medtactics's Avatar
1999 SC2
On a whim I decided to unplug the center lights after finding a splice for it and the tail lights are running on a 2.5amp fuse (thank God for LEDs).
Ripped/cut out the entire driver side carpet, it was wet and wasen't helping anything by just existing.
Looks like a mouse got it when I had to stop driving the sat for a month.
Old 08-22-2018, 09:10 PM   #13
Medtactics
Medtactics's Avatar
1999 SC2
https://m.imgur.com/a/Wm5pnRD
Well on the plus side I have the side brake lights for now, carpet on one side removed to my disgust, and a tangle of wires I shall take care of on some other day. Its been 8 hours, I'm tired, hungry, still covered in sweat from work earlier in the day, hand cut up, but God as my witness I have brake lights (sort of).
Now just to get new coolent/intake sensors, and a MAF sensor, removed the EGR so it would stop pushing the idle down to 400, and stop mimicking a vacuum leak sending the rpms to 4000 if I dare tapped the pedal (it's not the TPS, I checked) and allow me to cruise at 70mph with out throttle input.
Old 08-23-2018, 01:13 PM   #14
Saturn Night
By the time I made it to this thread, I was going to suggest a bare wire being grounded, but looking at your pictures, I see you found it already. Adopt a cat, and those mice will go bye-bye.
1998 Saturn sw2 rear brake emergency brake lever Dave27889 General Saturn Discussion 4 06-11-2016 12:01 AM
left and right brake lights don't work but centre high brake light works. microsat S-Series General 15 01-08-2014 11:44 PM
Where is the Foot Brake & Parking brake lead in a Astra rmlimage Astra General 2 07-22-2010 02:57 AM
Removing the parking brake cable from the park brake lever turbobuick33 S-Series Tech 3 12-29-2008 07:32 PM
'95 SL1 Third Brake light works tail brake lights dont' DazMan S-Series Tech 3 03-10-2005 01:20 AM
