Old 05-30-2018, 02:34 PM   #1
silver sl
silver sl is on a distinguished road
Default Best aftermarket motor mounts?
I want OEM but the top mount is discontinued. So whats my next best option?
silver sl is offline   Reply With Quote
Old 05-30-2018, 02:39 PM   #2
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
1996 SC2
1999 SC2
Default Re: Best aftermarket motor mounts?
This is not OEM but it will work. Westar EM2827 Engine Mount
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Mark_b is offline   Reply With Quote
Old 05-30-2018, 03:17 PM   #3
ErikTande
ErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the rough
ErikTande's Avatar
Don't worry about getting an OEM, I can't imagine paying $150 for one. I've put the $17 Westar top mount from Amazon on 3 different cars (1996 sl1, 2001 sl2, 1997 sw2) and have had buttery smooth results with all 3, no more rattles.
https://amzn.to/2HEyw1H
http://www.youtube.com/velocitylabs
ErikTande is offline   Reply With Quote
Old 05-30-2018, 05:29 PM   #4
Integral
Integral has a spectacular aura aboutIntegral has a spectacular aura aboutIntegral has a spectacular aura about
1993 SC2
I recently replaced my top motor mount with the Westar EM2827 and much of the vibration I was experiencing vanished.
The Westar EM2827 is a solid design (similar to OEM) and NOT the much maligned "frowny" design.
One caveat though. I needed to enlarge, via a dremel with a small grinding wheel, the frame side holes to make it fit over the studs; the engine side holes lined up perfectly.
Westar EM2827 https://www.rockauto.com/en/moreinfo...020&cc=1266768
Here is an Richpin video detailing the procedure:
Top Motor Mount Remove & Replace
https://www.youtube.com/watch?v=zaugUfILmGE
Integral is offline   Reply With Quote
Old 05-30-2018, 10:33 PM   #5
If you still want an OEM top mount, this seller still has them. Several here have purchased from them in the last few months, based off this link.
https://www.ebay.com/itm/92-02-Satur...xaND7m&vxp=mtr
Note: Seller is away until June 2nd, 2018 though.
Old 05-31-2018, 01:21 PM   #6
Seller says they only have about 10 left.
I am in no way promoting this seller over any other source, but just fully realize that other than this guy, no one else seems to have any original TAM's left.
Other than grabbing an OEM off of a wreck or junked car, we are stuck with DEA/Anchor and other such TAM replacements.
Unless as Fetchitfido once alluded to, fill the TAM void with some kind of window or silicone putty or...I don'know what. Someone needs to experiment with substitute materials and discover a solution.
Old 05-31-2018, 01:27 PM   #7
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
^^ that says more than 10 available, not about 10 left
97 SL2, auto, 123K miles
Old 05-31-2018, 04:33 PM   #8
I know, but I have today, been in direct emails with the seller....they just haven't changed their ad.
Old 05-31-2018, 05:38 PM   #9
Zeebins
Zeebins's Avatar
Well that's unfortunate then. Hopefully these westar mounts are as good as other claim them to be.
Old 06-02-2018, 06:26 PM   #10
MobileSaturn
MobileSaturn is on a distinguished road
1999 SL
I can confirm that both the Westar and the old DEA A2827 mounts suck. They're great at first and when the weather is warm, but as others have noted, the solid design is really only good if you don't put more than 5k on your car each year, or if you race your car. Otherwise you'll likely get vibrations bad enough to cause damage to your exhaust. In my case, I put about 15k on my car a year, so I need a good design.
Thanks toggenburg, ordered one of the OEMs for myself before they're all gone.
MobileSaturn is offline   Reply With Quote
Old 06-02-2018, 06:27 PM   #11
Medtactics
Medtactics is just really niceMedtactics is just really niceMedtactics is just really niceMedtactics is just really nice
Medtactics's Avatar
1999 SC2
You... you could use a groundpounder V2
If any user helped you, be sure to rep them.
Late 99 SC2 2.5 Gen, 237k miles
"Well... Now my car looks like a blackbarry." - Medtactics, 2017
Medtactics is offline   Reply With Quote
Old 06-03-2018, 07:47 AM   #12
Anchor sells both solid and frownie style mounts under the same part number, A2827.
I used one of the solid Anchor mounts in my SL2 for 8 years /100k miles and it's still in good shape.
wouldnt be surprised if Westar, DEA, and Anchor mounts are all made by the same company and reboxed / rebadged for sale
Old 06-07-2018, 12:04 AM   #13
Mike R
Mike R is on a distinguished road
2000 SL2
I replaced mine with a DEA/TTPA A2827HD Engine Mount https://www.ebay.com/itm/DEA-TTPA-A2...item1ed384b55f I replaced only the top mount and it's like a new car, zero vibration.
2001 SL1 5 speed
2000 SL2 Automatic
Mike R is offline   Reply With Quote
Old 06-07-2018, 10:46 AM   #14
Nekomimi
Nekomimi is on a distinguished road
Nekomimi's Avatar
1996 SL1
My 2017 production DEA is still going good, I think it's like the poly Dog-bone inserts, if you engine is smooth, it's not going to cuase excess vibes.
'96 SL1 Originally the family car, passed on to me as my first. "Hellcat" 240,000+ miles and purring smooth.
My Mug is filled with the lost souls of imports.
Nekomimi is offline   Reply With Quote
Old 11-10-2018, 03:54 AM   #15
sc2 saturn
sc2 saturn will become famous soon enough
so what is the "true" long lasting motor mounts DEA SKP Westar Anchor Pioneer? reading here its like 50-50 between DEA n westar then i see other brands and im lost on what to pick i want one that will last me another 230k++
sc2 saturn is offline   Reply With Quote
Old 11-11-2018, 10:18 AM   #16
Macgyver
OEM is the only one that's going to last 200k+. The China mounts will last 1-2 years.
Old 11-11-2018, 10:40 AM   #17
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
1996 SC2
Even the anchor frowny mount feels great for the first couple months. The quality shows in longevity.
-Robert
Old 11-11-2018, 10:43 AM   #18
I think it's a YMMV situation. My DEA mount is still going strong.
That said, Chinese products are not known for high quality control. It's possible that at some point, their source for rubber slipped in some lower quality stuff in certain batches.
It's also possible that some of the mounts mentioned in the thread above were not installed properly - something did not get properly torqued, they forgot to loosen and re-torque the lower mount bolt, etc.
motor mounts and transmission mounts help saturnmommy S-Series Tech 13 05-22-2017 08:17 AM
Aftermarket trans mounts and torque mounts terminal89 S-Series Tech 5 07-30-2016 09:55 PM
Are there any any worthy aftermarket top mounts out there? ssewall S-Series Tech 15 11-02-2011 10:42 PM
WTT: SPS Motor Mounts for Stock Motor Mounts soccer69er Classifieds 1 10-28-2004 07:13 PM
Aftermarket motor mounts hotrodSC2 Mods and Performance 11 04-16-2003 05:25 PM
