Old 10-25-2007, 01:16 PM   #1
jimmmm
jimmmm is on a distinguished road
Default SL2 oil leak & Rear oil seal kit parts id
Just rebuilt our saturn Sl2 DOHC engine, engine runs great but after running it a very short time (up to about an hour or so) I noticed it is now leaking from rear of engine somewhere near oil pan and rear main engine oil seal ( I still need to take off engine to tranny brace and small black flywheel cover to help identify source)
Can't see any oil dripping down from valve cover , yet. Need to see edge of oil pan after removing items mentioned above & retorque bolts and/or remove & reinstall with black RTV sealer for gasket (as was completed first time).
I have a few questions that may help me solve this issue:
1); When using RTV sealer for oil pan gasket which type is best to use ? The Felpro gasket kit came with black RTV and i use this first time around.
2); When using RTV should I : smooth it with finger or leave it a bead ? Let it tack up several mins. or install immediately.
3); I looked up a replacement rear main seal kit on line and it shows the main seal (the large rubber seal) and a small round 'O' ring type seal with it..... what is the small one for / where does it go ? (I do not remember having/installing the small 'O' ring type seal the first time around... but will be checking into it)
jimmmm is offline   Reply With Quote
Old 10-25-2007, 02:50 PM   #2
saturnhouse
saturnhouse will become famous soon enough
Default Re: SL2 oil leak & Rear oil seal kit parts id
I used Rite-stuff on my oil pan.
First, removed all previous RTV, cleaned both surfaces with break clean. Then applied a generous bead to the channel on the pan. Pressed carefully into place, bolted, and no leaks so far (knocking wood). Its been almost 2 years.
saturnhouse is offline   Reply With Quote
Front Crankshaft oil seal leak 1andonly S-Series Tech 6 08-18-2009 05:48 PM
Engine parts? oil pump o-ring, rear main seal gasket. sc2dohc94 S-Series Tech 2 03-22-2008 12:19 PM
2000 SL2 What is the 'O' ring for that comes with Felpro rear seal; oil gally plug ? jimmmm S-Series Tech 7 10-29-2007 05:08 PM
Oil Leak? Not oil pan, not valve cover, not front oil seal. klcl S-Series Tech 14 10-05-2007 12:25 PM
front crankshaft seal oil leak PACT Man S-Series Tech 8 04-01-2006 12:14 AM
