Old 10-20-2005, 05:25 AM   #1
Fricken eh!
Fricken eh! is on a distinguished road
Default Leak from auto trans, Upper Pan area????
I have a leak on my auto trans in my 94 SL2. It "appears" to be coming from the upper pan on the transmission located near the battery area. Is there a gasket for this, or do you use silicon sealer? How hard is it to change? I've searched, but couldn't find a post about this here.
Thanks!
Fricken eh! is offline   Reply With Quote
Old 10-20-2005, 07:33 AM   #2
PeteB
PeteB is on a distinguished road
PeteB's Avatar
2002 L-Series 3.0L Sedan
1994 SC2
Default Re: Leak from auto trans, Upper Pan area????
Could it be from the filter? Mine leaked when I got the car, I changed it following instructions, and just noticed last night that it's leaking again. Going to give it a twist with a wrench.
PeteB is offline   Reply With Quote
Old 10-20-2005, 08:10 AM   #3
SaturnTech
SaturnTech is on a distinguished road
SaturnTech's Avatar
Thanks!
Yes there is a gasket for the valve body cover. Early S-Series use a fiber gasket, later ones have a metal and rubber gasket. It's very easy to change.
SaturnTech is offline   Reply With Quote
Old 10-20-2005, 09:31 AM   #4
irish56
irish56 is just really niceirish56 is just really niceirish56 is just really niceirish56 is just really niceirish56 is just really nice
irish56's Avatar
1999 SC1
I'll second that - I did this job on a '95 SL1 several years ago. Remove the intake and air filter housing, the battery and the battery tray, and the top cover of the transaxle is right there. Just be sure to clean everything up before you remove the top cover so you don't drop any filth into the transaxle. I got the gasket from the Saturn dealer - it was fairly cheap (around $15 IIRC) and had a bead of sealer on one side already so I didn't have to use any RTV. Hasn't leaked a drop since.
irish56 is offline   Reply With Quote
Old 10-20-2005, 10:12 AM   #5
Luke
Luke's Avatar
Default May we assume you mean the Upper, "Cover" on the Transmision ??
>Is there a gasket for this, or do you use silicon sealer? How hard is it to change?<
>FM SaturnTech: Yes there is a gasket for the valve body cover.....It's very easy to change.<
>Fm Irish: I'll second that - I did this job on a '95 SL1 several years ago.............Remove the intake and air filter housing, the battery and the battery tray,<
And I'll third this: For I did this a couple of weeks ago, and found it very simple. Keep in mind, though, that in removing the battery tray, you'll have to remove a bolt which condibutes to its support, by removing the the driver's side tire and you'll see the, rather long, bolt located near the top of the tire well.
I'd also suggest that you get the gasket from a dealership, for you'll notice it is very well designed. BTW, the red center full gasket ring on the gasket, faces UP, with the none colored center of the gasket facing down, directly onto the transaxle.
Luke is offline   Reply With Quote
Old 10-20-2005, 04:36 PM   #6
Fricken eh!
Default Re: May we assume you mean the Upper, "Cover" on the Transmision ??
thanks for the replies everyone! i will check into it this weekend!
Auto trans leak thutton S-Series Tech 2 12-17-2007 04:20 PM
leak in plastic area under upper radiator hose intake. technopop L-Series Tech 0 06-28-2007 03:00 PM
What did I screw up? Auto Trans Pan Gasket 94 SL2 Fricken eh! S-Series General 8 10-17-2006 01:31 AM
WTB: '97 or later SC or SL Auto trans NC Area BarnOwl Classifieds 0 06-26-2006 02:51 PM
Auto Trans Leak ricksLS1 L-Series General 5 03-09-2004 01:32 PM
