Old 12-24-2020, 02:57 PM   #1
rsnuke
rsnuke is on a distinguished road
Default Help, 2008 Saturn Vue (I4) 2.4L died on road.
Hello all,
For the first time, I seem to need help. Got a Saturn 2008 Vue, that just "died" on me... While on the road, 5 minutes before it died, it was making a sound like "a heat-shield was vibrating" going along with revs (more rev more of a metal shield sound) also was DOWN on power...
I *thought* I got off time... seems like ecotec I4 have bad tensioners for timing chains. Only codes I have are P0011 and P0013. And restarting makes horrible metal crunchy sounds. after 2-3 tries, and it did turn over, but no start, with a 2000Amp jumper, and on the 3 attempt, terrible metal noise on cranking so I stopped and got it towed, on its on, it doesn't start or turn... could be something "stopping it from turning over" or weak battery but that is secondary.... a starter is not the issue... Remember the engine died while on the road...
So going with my "timing off" idea, I removed valve cover, seems like timing chain is good. So I'm STUMPED! My next action will be to remove aux belt, and see if I can crank the engine from the bottom crank shaft...
Maybe alternator? will find out once I remove the belt and attempt a manual crank... 720' to see if any obstructions and validate timing belt marks.
Anyone have any experience? I'm stump... picture of timing looks ok. Help!
https://drive.google.com/file/d/194x...ew?usp=sharing
rsnuke is offline   Reply With Quote
Old 12-26-2020, 03:54 PM   #2
rsnuke
Default Re: Help, 2008 Saturn Vue (I4) 2.4L died on road.
As suspected, Timing Chain guide broke.
https://imgur.com/hiTw4wb
Now wondering if engine slipped off timing. And how badly...
I hope and pray no valve damage, will check timing marks from cam, looking for 10am - 2pm marks...
Old 12-27-2020, 12:15 PM   #3
Bill Murray
2007 ION-2 Quad Coupe
1997 SC1
Can you post the miles on your engine? I'm just curious. Thanks
Old 05-16-2021, 08:35 PM   #4
Cavell
2003 VUE 3.0L
Long time. Motor dead?
94 sl died in road , wo't start. fletch62 S-Series Tech 8 03-01-2017 03:45 PM
Video: 2008 Saturn Astra XR 5dr and State 300/Ross Hollow Road Run pix Astra General 0 01-20-2009 11:11 AM
Road-Tripping in Style with the 2008 Saturn Outlook Charlie Community Center 0 09-02-2008 06:15 AM
2008 Saturn Astra XR 3-Door Road Test Charlie Astra General 0 04-23-2008 12:46 AM
2008 Saturn Astra Road Test Photos Charlie Astra General 7 01-28-2008 02:40 AM
