Closed Thread
Old 01-09-2004, 11:09 AM   #1
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Default L brake caliper bolt size
Had no luck on the L forum with this, so thought I'd try it here.
Tried to do the front brakes the other day and didn't have the right tools to get the caliper off. Anybody know what size allen wrench it takes to get the bolts off?
I'm gonna replace them with regular bolts when I put the calipers back on, anybody know what size and thread those bolts are?
TIA,
Jerry N
Groucho Marx
s3nfo is offline
Old 01-09-2004, 11:36 AM   #2
eljefino
eljefino's Avatar
1995 SW1
2000 SL1
Default
I know my S was an 18mm which might befuddle some as most wrench sets go from 17mm to 19mm.
eljefino is offline
Old 01-10-2004, 01:29 AM   #3
ssicarman
ssicarman's Avatar
Default
The slide pins on the calipers should be an 8 mm hex. The caliper mount bolts should be a 10 mm hex and the bolt that holds the rotor in position should be a 5 mm hex. The one holding the rotor on cant really be replaced by a normal bolt, it would stick out to much to remount the rim. The caliper slide bolts can't use a regular bolt because they only have a small portion of thread on them and the rest is smooth slide surface. That and they are likely a non standard thread and daimeter size to prevent people from using regular bolts.
ssicarman is offline
Old 01-10-2004, 03:16 AM   #4
amazinghl
Default
I have a 18mm socket just for that job.
00 Insight 72mpg
amazinghl is offline
Old 01-11-2004, 11:07 AM   #5
s3nfo
s3nfo's Avatar
Default Thanks
Thanks, guys!
Jerry N
Groucho Marx
s3nfo is offline
Closed Thread
Seized brake caliper bolt. Eliot S-Series Tech 28 09-25-2011 03:22 AM
Front Brake Caliper Bolt specs tfgorman S-Series Tech 9 01-17-2008 10:17 AM
Front brake caliper bolt torque specs bassplayrr Vue Tech 7 12-26-2006 05:42 AM
Brake Caliper Bolt Torque frog8546 S-Series General 9 07-25-2005 09:21 PM
caliper bolt size s3nfo L-Series General 0 01-07-2004 10:57 AM
