Old 10-25-2003, 04:59 PM   #1
brotherhay
brotherhay is on a distinguished road
Dizzy instrument panel non functioning
I recently purchased a '93 SL2. It had some minor problems, and one that I cant figure out. The instrument panel is non-functional, and its not the fuses. The lights work that illuminate the panel, but the tach, speedometer, odo, trip, fuel and heat gauges dont work at all. Before i go drop a substantial amount at a dealer, maybe someone could give me pointer at how i could approach fixing it myself. I am electronically literate so i should be able to achieve the task if its not too involved. Please help me!!!!
brotherhay is offline
Old 10-25-2003, 05:07 PM   #2
sloppyo
sloppyo is on a distinguished road
Default
have you checked the intrument panel fluid lately???
sloppyo is offline
Old 10-25-2003, 05:17 PM   #3
Dr. Bob
Dr. Bob is on a distinguished road
Default
Snorted pop out my nose when I read that!!!
I'd say get a manual and test light, then troubleshoot the power and grounds to the gauge cluster to start. You do know that there is an underhood fuse panel and another in the console on the passenger side, right?
Dr. Bob is offline
Old 10-25-2003, 06:58 PM   #4
GRIFF
GRIFF is on a distinguished road
Default
Brother ~ Looking at my haynes manual for 91-99 saturns,In the instrument cluster wiring diag. It appears they all use the same ground ( i/p splice pack ( gnd) where ever that is. I need more time to study this thing.
do your turn signals light up ~ They will use this same ground also. as do your illumination lights. but one quick thing I see is the power feed is different for the gauges vs the illum. lights
The books says the feed to the speed,odometer,tach fuel temp feed off ( IGN 1 FUSE ) not sure where that is yet ~ I need to eat dinner and will study and try to get back to you
Greg
GRIFF is offline
Old 10-25-2003, 07:25 PM   #5
GRIFF
Default
Does your service engine soon light up when you first turn the key? And how about the seat belt light . They also use the (IGN 1 FUSE ) Wich even though the layout in the book looks different then I remember from looking at the fuse box yesterday .It should be a 10 amp fuse by the passanger side kick plate marked ( IGN1 ) I know you checked fuses but you may want to pull this one and double check with an ohm meter.
I read a post yesterday that someone used a cheap tester and didn't find the bad fuse.
If the fuse reads good, then pull the kick plate off the drivers side look all the way through to the back of the fuse box
http://www.saturnfans.com/photos/sho...t=12072&page=1
and see if anything is loose. Did anybody add any after market items to this car?? What minor problems did the car have before you bought it ?
The picture from the above link is out of my 95SL2 I'm not sure if yours will look the same
Greg
GRIFF is offline
Old 10-25-2003, 07:52 PM   #6
GRIFF
Default
Well it looks like wolfman is over in ( tech talk ) answering your question . I didn't know you posted it there also . So print them both off and let us know how you made out.
Follow his instructions first ` He's been around
GRIFF is offline
Old 10-30-2003, 03:02 AM   #7
XtremeGrandAm
XtremeGrandAm is on a distinguished road
Default
lol thats a good one
XtremeGrandAm is offline
Instrument Panel dogpile S-Series Tech 8 02-09-2007 09:39 AM
Who knows how to get the instrument panel out? ryanmcabee Vue General 2 12-19-2005 03:26 PM
Instrument Panel.. Help!! JoshM20 S-Series Tech 3 05-23-2005 04:30 AM
Instrument panel SaturnVue'03 Vue General 8 12-26-2003 11:22 PM
instrument panel non functioning brotherhay S-Series Tech 2 10-25-2003 09:19 PM
