Old 03-09-2013, 09:38 PM   #1
Stuffburger
Stuffburger is on a distinguished road
Default 1998 SL2 went from running fine to terrible compression just sitting for a weekend
1998 SL2, 120k miles.
My GF's car was running fine last friday, just the normal moderate roughness and noise, to completely unable to start monday morning. It cranks over just fine but won't start. After a lot of other tests and finding everything fine (verified spark and gap, fuel injectors, fuel pump, fuses, relays, MAP sensor, timing chain, wiring- everything in the manual for a cranking but not starting engine) and going crazy for a bit, I checked compression and got some really lousy numbers- around 120, 80, 30, 60 if I recall correctly.
Am I missing anything else that could cause the car not to start? What could cause the car to go from running fine to compression too poor to start at all just sitting for a weekend? Am I correct now to take off the head and verify the condition of the head gasket?
Thanks for any input!
Stuffburger is offline   Reply With Quote
Old 03-09-2013, 10:22 PM   #2
lamping.ap
lamping.ap will become famous soon enoughlamping.ap will become famous soon enough
Default Re: 1998 SL2 went from running fine to terrible compression just sitting for a weeken
Min compression is 180. Are you sure you performed the test correctly?
lamping.ap is offline   Reply With Quote
Old 03-10-2013, 01:27 PM   #3
Stuffburger
I had the same thought and also tested my '95, which is running fine, and got numbers around 200 with the same test kit and procedure.
Old 03-10-2013, 05:49 PM   #4
Spaghettiohead
Spaghettiohead is on a distinguished road
Was the battery charged completely?
Spaghettiohead is offline   Reply With Quote
Old 03-10-2013, 09:05 PM   #5
Stuffburger
Well, I dove in figuring it had to be a bad head gasket. It turned out to be fine, but I found the culprit- the timing chain tensioner arm had broken and I'm guessing the chain had started skipping teeth, getting the timing all kinds of ****ed up. Now I just gotta take off the oil pan and hope the broken chunk is in there
Tags
compression, head gasket, low compression, sl2
Reusing Water pump after running and sitting with oil-contaminated coolant Eazy340 S-Series General 5 09-04-2012 12:58 PM
Vue idles fine, runs terrible, like a bucking BRONCO live2beotch Vue General 7 02-23-2007 05:17 PM
My terrible compression problems ad198592sl2 S-Series General 4 10-24-2005 06:44 PM
Battery light, but car's running fine! callmethewander S-Series Tech 9 06-17-2005 08:04 AM
'97 SL1, running fine, but... machine_man S-Series General 4 12-13-2004 01:05 AM
