Old 10-11-2010, 11:23 PM   #1
pyroom
pyroom is on a distinguished road
pyroom's Avatar
2004 VUE 3.5L
Default Vtec light?
Just thinking, how cool would it be to make that "vue" emblem that everyone pushes light up when vtec kicks in? Should be a pretty easy mod right? Just find the vtec wire and solder an LED on it?
2004 Vue 3.5L AWD
pyroom is offline   Reply With Quote
Old 10-12-2010, 01:54 AM   #2
nitroussaturn
nitroussaturn will become famous soon enough
nitroussaturn's Avatar
Default Re: Vtec light?
its been done a million times on honda's and most consider it "ricey" now lol
but yeah tap the wire from ecu to positive side of light,make sure to put a capicitor inline and hook the other wire from light to ground
2004 REDLINE FWD TONS OF MODS..CLICK HERE http://www.cardomain.com/ride/3144619
1999 MERCEDES BENZ AMG E55,MY DD VETTE KILLER
2000 328I M3 RIMS
nitroussaturn is offline   Reply With Quote
Old 10-12-2010, 03:30 AM   #3
burnout
burnout's Avatar
I always liked this on the Celica GT-S where the gauge color changes when lift (VTEC) kicks in
http://www.youtube.com/watch?v=k2K2c3QQgSA
I almost tried installing a VTEC light back on my old '05 actually. The solenoid is above the oil filter in the passenger side wheelwell. One wire to tap.
I don't know how I would have gone through with it tastefully, but I managed to figure that out with everything else
The VUE logo in the "tape deck" above the radio is a good idea
'13 VW CC 2.0T
'99 Volvo S70 AWD
Old 10-12-2010, 08:41 AM   #4
pyroom
pyroom's Avatar
2004 VUE 3.5L
Thanks, I think I might give this a try.
From what I've read we should get vtec in neutral right? Just so I can test it.
2004 Vue 3.5L AWD
Old 11-15-2010, 06:24 PM   #5
pyroom
pyroom's Avatar
2004 VUE 3.5L
Does anyone have a wiring diagram from the ECU for me? I'm looking for the Vtec solonoid wire. I think it would be easier to tap the line at the ecu rather than the solonoid itself.
Thanks in advance
2004 Vue 3.5L AWD
Old 11-15-2010, 08:43 PM   #6
XRL
XRL's Avatar
2004 VUE Red Line
http://cgi.ebay.com/200-5mm-Dual-Bi-...4#ht_627wt_905
These are what you'd want to make your gauges change colors. Need resistors for each positive lead, and a way to kill the one leg when the other turns on. After that, you're good.
Old 11-15-2010, 11:33 PM   #7
far2grumpy
far2grumpy's Avatar
It appears you need to be underway for VTEC to engage - here's service manual extract:
System Operation
The rocker arm oil control system is an electronically controlled, hydraulically operated system that provides good low speed torque and high speed horsepower. The engine control module uses an electronic solenoid to control the flow of oil to the rocker arms. In order to determine when to transition from low to high speed operation, the control module relies on the following information:
 Engine speed
 Engine load
 Engine operating temperature
 Vehicle speed
Old 11-16-2010, 12:21 AM   #8
XRL
XRL's Avatar
2004 VUE Red Line
It's been said that most V6 powered Vues can't use VTEC in 1st as well, a GM gimp to protect some of their parts.
I think it'd be easier to grab the wire at the solenoid honestly.
Old 11-16-2010, 12:39 AM   #9
mrtube
mrtube is on a distinguished road
I don't understand what a capacitor inline will do other then cause a light to not light unless its being fed AC??
mrtube is offline   Reply With Quote
Old 11-18-2010, 07:30 PM   #10
far2grumpy
far2grumpy's Avatar
Thanks in advance
pyroom - diagram attached. Will you post results if this works out?
Old 11-19-2010, 01:45 AM   #11
pyroom
pyroom's Avatar
2004 VUE 3.5L
Thank you far2grumpy,
I will post results, although don't expect anything right away.
2004 Vue 3.5L AWD
Old 12-23-2010, 01:22 AM   #12
teamsheetz
teamsheetz is on a distinguished road
yo man you get anywhere with this im looking to do this with mine too thats pretty dope if you got it done can you tell me what you bought to do this? im a little confused on what i need to buy to do this so i dont burn the bulb up and **** an to attach it a the solenoid?
teamsheetz is offline   Reply With Quote
Old 12-23-2010, 11:02 AM   #13
SC2BuzzBomb
SC2BuzzBomb is on a distinguished road
This mod is complete cheese. Why not spend your precious monetary and time resources on doing something that actually increases performance? Vehicels have come along way in the past few years and the RL VUE is not really a "performance" vehicle anymore, it'll get smoked by all big V-8 mule pickup trucks and by most V6 CUV's these days.
Throw a bottle on the thing and have something light up when you hit the "go button".
SC2BuzzBomb is offline   Reply With Quote
Old 12-23-2010, 02:22 PM   #14
pyroom
pyroom's Avatar
2004 VUE 3.5L
This mod was free... it cost me 15 minutes of my time. I have hundreds of feet of wire laying around, and I took a bright blue led from a broken external hard drive case. I just need to mount it behind the dash now & I'll be done. If you owned a Vue, you would know how annoying the "Vue" emblem in the dash is - I had to make it do something.
I'm not sure what you mean by most trucks will kill it - I've yet to see a truck beat me.
2004 Vue 3.5L AWD
Old 12-27-2010, 03:32 AM   #15
nitroussaturn
awww yeah MOST newer truck will kill it...even my pretty decently modded one.thats why i drive the e55 most of the time lol
2000 328I M3 RIMS
Old 01-08-2011, 07:11 AM   #16
nitroussaturn
so the million dollar question is does the light come on in 1st gear?
2000 328I M3 RIMS
That thing got vtec? mofolicious Vue Red Line 17 05-04-2008 12:32 AM
Vtec ? Hellrazor Vue General 1 04-08-2008 07:57 PM
Vtec Controller tuscani66 Vue Red Line 2 01-30-2008 09:33 PM
How sure are we that the V6 isn't VTEC? TXVue04 Vue General 14 05-17-2004 11:32 PM
Vtec?? criticalmass Vue General 7 04-13-2004 06:51 AM
