Old 09-13-2010, 10:35 AM   #1
saturn95
saturn95 has a spectacular aura aboutsaturn95 has a spectacular aura about
saturn95's Avatar
2001 SL2
2007 ION-2 Sedan
Default Type of power lock on third gen Sl2?3 Wire Negative?3 Wire Positive?
I am trying to find out what type of power locks my 2001 Saturn Sl2 has?
There is a website that explains how each system works and I want to know what type do the saturns have.
Here is the site : http://www.the12volt.com/doorlocks/doorlocks.asp
Thanks.
saturn95 is offline   Reply With Quote
Old 09-13-2010, 12:18 PM   #2
saturn95
saturn95's Avatar
2001 SL2
2007 ION-2 Sedan
Default Re: Type of power lock on third gen Sl2?3 Wire Negative?3 Wire Positive?
I pulled the stock power switch from a donor car and it has three pins. When you flip the switch one way it completes a circuit between the middle pin on the connector and the next pin to the left. If the switch is flipped the other way it completes the circuit with the middle pin and the pin to its right. But I still cant tell what type of system this is. Has anyone ever worked with the power locks?
Tags
power locks
Which speaker wire is positive? Striped or solid? gotjeepzj Astra General 7 07-23-2010 07:32 AM
Saturn alternators: 1-wire, 2-wire, 3-wire? JohnHupp S-Series Tech 5 11-25-2008 08:10 PM
Wire RKE to flash lights for LOCK/UNLOCK? rearviewmirror S-Series Tech 2 11-07-2007 07:44 PM
Installing aftermarket remote start ... power door lock wire? paulygon S-Series General 1 05-28-2006 09:35 PM
ignition wire/spark plug wire - resistance/ohms Heartbeat - '95 SL2 S-Series Tech 3 10-17-2005 02:09 PM
