Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 09-02-2008, 02:38 PM   #1
xternal
xternal is on a distinguished road
xternal's Avatar
2005 VUE Red Line
Default Center Bezel and Window Controls
Needless to say I have the patience of a 10 year old.. I made an attempt to paint the center bezel and plastic piece this past weekend. It looks like crap and will have to be redone. Sense I am doing "black" I figured it might be easier to find one than re-do this one. In any case I need to confirm how wide my net can be. I have a 2005 Redline somewhere i read that the standard 2005 bezel is black... what other years has this same model.
Also once I find one, if anyone wants the old one and has more patience than I hit me up!
xternal is offline   Reply With Quote
Old 09-02-2008, 05:16 PM   #2
Xboxer
Xboxer is on a distinguished road
2004 VUE Red Line
Default Re: Center Bezel and Window Controls
The paint on these centre consoles has been an issue on my 2004 Redline (and others) too. I had mine replaced under warranty.
Xboxer is offline   Reply With Quote
Old 09-02-2008, 06:57 PM   #3
FGCA_XRL
FGCA_XRL will become famous soon enough
2004 VUE Red Line
The 05s should have it in black already I believe. I haven't gotten around to painting mine yet either.
FGCA_XRL is offline   Reply With Quote
Old 09-02-2008, 09:47 PM   #4
xternal
xternal's Avatar
2005 VUE Red Line
Being that I tried to fix myself I would be surprized if they would actually give me a replacement. I may try it though
Old 09-03-2008, 08:56 AM   #5
docderek05
docderek05 is on a distinguished road
2005 VUE Red Line
Mine is a mess too..all peeled and looks so cheap and really is
frustrating..I know its not a high end car, but I have it really
cleaned up and looks great all the time except for this terrible peeling
center dash, especially around the window buttons, and gauges.
Does anyone know of a manufacturer of a Dash Kit that is subtle..I have seen some
really cheezy looking installs..I mean something in a very mild wood grain,
like the trims on the 07 interiors..or a decent looking brushed aluminum?
for an 05. I would only want to install around the center stack not all
the lil trims around the ac vents etc. Any Ideas? other than painting it? Regards to all..Doc
docderek05 is offline   Reply With Quote
Old 09-03-2008, 11:48 AM   #6
04Vuesilver
04Vuesilver is on a distinguished road
2004 VUE Red Line
Can someone post a picture of this, becuase I haven't had any problems with my dash, and never even knew it was a problem until just recently from the boards
04Vuesilver is offline   Reply With Quote
Old 09-22-2008, 08:26 AM   #7
xternal
xternal's Avatar
2005 VUE Red Line
Update.. So I ended up getting another bezel and piece where the window controls are... guess what, the paint is peeling as well
So now I have two sets. I am going to give it another shot, but now have the extra set. I posted in classified but no bites. One quick question though, need some better suggestions on getting the coating off, the paint thinner method doesn't seem to work well.
Old 09-22-2008, 03:45 PM   #8
FGCA_XRL
2004 VUE Red Line
I was going to try wetsanding. Think of it this way, you have a test mule you can screw up as badly as you want now.
Old 09-23-2008, 02:51 PM   #9
xternal
xternal's Avatar
2005 VUE Red Line
Did some work last night and got it sanded pretty well. Used some oven cleaner (per another thread) and it actually worked (or at least loosened it a bit..) in any case, I had some wheel paint in silver that I thought I might see what it would look like, so I decided to hit it. Not sure I like the silver but it is almost a dead match to the door handles. If I get a chance I will try to post some pics later...
Old 09-23-2008, 03:20 PM   #10
FGCA_XRL
2004 VUE Red Line
This is worthless without pictures. We demand pictures.
Old 09-29-2008, 02:29 PM   #11
xternal
xternal's Avatar
2005 VUE Red Line
I know I keep trying to snap a few. I ended up swapping out this weekend the window control came out nice but the bezel is still not to my liking. I will take some either tonight or tomorrow and post. Now if someone will buy the old ones, so I can buy more stuff! I have been on restriction form the wife
The old ones need a little sanding and paint but if anyone is thinking of doing this, better to use this one instead. one quick request though, if anyone happens to have or access to a fog light switch, I could really use it. I ended up breaking mine and the dealer wants 50.00 for replacement! I am tempted to try to get them to replace on warranty, but with the 100.00 deductable not really worth it...
Old 09-29-2008, 02:47 PM   #12
FGCA_XRL
2004 VUE Red Line
Hot glue that thing back in, they all break. Hot glue works great though.
Old 09-29-2008, 04:26 PM   #13
xternal
xternal's Avatar
2005 VUE Red Line
I wish, when I took it out of the original I pushed to hard on it and fell on the garage floor. Must have caught perfect because the thing broke. I put it back together and thought I had it right, but when I went to press the switch it stayed depressed. I now have to remove the bezel, (again) ... I wouldn't worry about it as I usually just leave it on so fogs run with headlights, but they are not on..
Old 09-30-2008, 11:20 AM   #14
phatbasterd
phatbasterd is on a distinguished road
Sounds like your missing the srping. I lost mine also used a spring out of a click pen and works just fine for me try that.
phatbasterd is offline   Reply With Quote
Old 09-30-2008, 04:18 PM   #15
xternal
xternal's Avatar
2005 VUE Red Line
There's a spring inside the switch? That could be a good possibility then. When I dropped it I thought I got all the pieces...Now I just needs some time to take this thing off for the 10th time!
Old 10-03-2008, 09:13 AM   #16
NJ FRR
NJ FRR is on a distinguished road
NJ FRR's Avatar
2006 VUE 2.2L
i just started mine doing that to and it s really starting to bother me looks like crap....anyone try going to the dealer to get it replaced?
NJ FRR is offline   Reply With Quote
Old 10-10-2008, 03:05 PM   #17
RL2NV
RL2NV is on a distinguished road
2004 VUE Red Line
I just peeled off all the paint on mine and it looks great.The dash is all black.
RL2NV is offline   Reply With Quote
Center Bezel replacement (Dash piece around radio) mellissam Vue General 2 05-07-2007 12:19 AM
WTB:first gen sc center shifter bezel,not the armrest fastion Classifieds 0 03-05-2006 12:45 AM
Painting the Center Bezel Juba310 Ion General 13 07-07-2005 09:09 PM
WTB 2004 Vue Center Dash Bezel Grey blkprl Classifieds 4 07-05-2005 04:35 PM
Whats the Deal - No Power Window Controls Delvis General Saturn Discussion 12 09-23-2002 01:17 PM
