Old 08-18-2015, 10:12 PM   #4441
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
Default Re: What did you do to your S-Series today...
I finally got around to replacing the ECTS connector following Richpin's YouTube tutorial. I originally tried to use a female bullet connector cleaner and some spray to clean out the the original connector, but there was a lot of green corrosion going on (courtesy of the old resin-tipped ECTS).
Despite the successful soldering and heat-shrinking, the temp gauge still sits just a bit over 1/4 when warmed up. I think my mistake may have been either not cutting off enough of the old wire, or using the ECTS from a 2001 SL2 instead of the IAT sensor. Now that I've done it, I cab always give it another shot at a later date.
Goggles Pisano is offline   Reply With Quote
Old 08-18-2015, 11:00 PM   #4442
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
Thermostat?
1999 SL2 A4 -96k miles
Currently sipping Mobil 1 + Delvac 1300 + LM2009 + Rislone
3 ounces Lucas UCL per fill-up
1993 SL2 SOLD @189k
NWSaturn247 is offline   Reply With Quote
Old 08-19-2015, 02:27 AM   #4443
J N Winkler
J N Winkler is a jewel in the roughJ N Winkler is a jewel in the roughJ N Winkler is a jewel in the rough
1994 SL2
Originally Posted by Goggles Pisano View Post
Despite the successful soldering and heat-shrinking, the temp gauge still sits just a bit over 1/4 when warmed up. I think my mistake may have been either not cutting off enough of the old wire, or using the ECTS from a 2001 SL2 instead of the IAT sensor. Now that I've done it, I can always give it another shot at a later date.
All S-Series cars (1991-2002) use the same ECTS. You can use a multimeter with 1/4-watt resistors as connector probes to ensure there is a 5 V drop across the connector when the key is on.
Your gauge is the post-1995 design, so "just a bit over 1/4" sounds about right, though it may be worth considering the thermostat if it has not been replaced recently.
J N Winkler is offline   Reply With Quote
Old 08-19-2015, 05:42 AM   #4444
Pitcher
Pitcher's Avatar
2001 10th Anniversary Edition:
Two, YES 2, rear wheel studs were stripped. Next to each other!!
Replaced them & torque'd to 103 Ft/Lbs.
Made sure ALL lug nuts were torque'd to 103 Ft/Lbs.
Owned 4 other S-Series.
Old 08-20-2015, 10:33 PM   #4445
bumpdraft
bumpdraft's Avatar
1998 SW2
Yesterday, I installed a fixed orifice PCV valve. Then, after trying to figure out exactly what a fixed 0.10 dia orifice does compared to the original check valve, I took it back off. It seems like a 0.01 dia hole would not provide for enough flow and too much crankcase pressure.
Anyway, the original idea was to install it on the (oil using) SL1
and
Backed off the throttle stop screw. The car was bouncing to 2000 rpm at cold start.
and
Today, added air. Car rolls better. My tire gauge was reading about 3 psi high and, with the cooler weather, the tires looked flat.
Old 08-22-2015, 08:49 AM   #4446
Pitcher
Pitcher's Avatar
Cleaned & inspected the rear drums on my 2000 SL2 aka Creampuff:
All looks good.
Don't ignore your brakes!
Old 08-25-2015, 09:35 AM   #4447
Sid
Sid will become famous soon enough
Sid's Avatar
1996 SW2
Cleaned and waxed just in time for grandpa's weekly grocery getter run.
96 SW2 5MT
Sid is offline   Reply With Quote
Old 08-25-2015, 09:57 AM   #4448
Bildo Baggins
Bildo Baggins is a jewel in the roughBildo Baggins is a jewel in the roughBildo Baggins is a jewel in the rough
Another session of headlight buffing and checked/topped oil. 5oz of Lucas into a full tank. Maybe a wash and interior clean later.
Bill from Extreme Southern North Carolina
'97 Satty SL2
280Kish miles
Bildo Baggins is offline   Reply With Quote
Old 08-26-2015, 12:11 PM   #4449
Highmile
Highmile's Avatar
performed my 580,000 mile oil change.
Wix 51516 and a nice fresh jug of Valvoline 5w-30...
Highmile
'95 SL1 580k and counting
Old 08-26-2015, 09:52 PM   #4450
jhonky
jhonky is on a distinguished road
Changed the alternator. Found it relatively easy. Top bolt had what looked like coolant on it. Filled up with 93 octane e10 from exxon
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
jhonky is offline   Reply With Quote
Old 08-27-2015, 01:21 PM   #4451
87z16
87z16 is on a distinguished road
did my headliner last weekend
99 SL2 maroon/beige
99 SL2 maroon/black
87 Monte Carlo SS Aerocoupe --- maroon/maroon - completely stock
85 Monte Carlo SS --- silver/maroon - not stock
tom
http://www.motortopia.com/87z16
87z16 is offline   Reply With Quote
Old 08-27-2015, 01:54 PM   #4452
SRGW
SRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to all
1997 SL1
Post Re: What did you do to your S-Series today...
Tire rotation on the 95.
1995 SL1 218,100 Well Oiled!!
1997 SL1 51,657 Just A Teenager!!
CHECK YOUR OIL!!
Old 08-27-2015, 02:30 PM   #4453
NWSaturn247
Checked the oil @ 4016 miles. History: initial fill M1TDT 5w-40. 2 quarts top-off of M1HM 5w-20. 1 quart Rislone Engine Treatment. 8 ounces of SeaFoam. Will do oil change soon.
1993 SL2 SOLD @189k
Old 08-28-2015, 11:43 PM   #4454
NWSaturn247
Change oil today. First added B12 to the oil and idled for 7 minutes. Turned off for 20 minutes. Then started again and idled for 10 minutes. Drained and filled with Smitty's Super S 5w-30 and a bottle of Motor Medic High Mileage Motor Flush. Idled for 7 minutes. Drained.
Fit a MicroGard MGL3614
Filled the Engine with:
1 quart of Valvoline MaxLife High Mileage 10w-40
2.5 quarts of Valvoline MaxLife High Mileage 10w-30
16.9 ounce bottle of Bar's Leak RMS Repair
~ half can of LiquiMoly mos2
1993 SL2 SOLD @189k
Old 08-29-2015, 05:42 AM   #4455
SW2 Driver
SW2 Driver has a spectacular aura aboutSW2 Driver has a spectacular aura about
SW2 Driver's Avatar
1998 SW2
Changed Valve Cover Gasket, Serpentine belt, oil, brake fluid, power steering fluid, and rotated tires.
SW2 Driver is offline   Reply With Quote
Old 08-30-2015, 08:49 PM   #4456
Ubie
Ubie is on a distinguished road
Check the oil and topped off the fuel tank.
Oil was good, put in 10.505 gal on 336mi for a nice and tidy 32mpg.
Ubie is offline   Reply With Quote
Old 08-31-2015, 07:58 AM   #4457
trottida
trottida's Avatar
Last week I replaced the front flex pipe on the exhaust and replaced the windshield.
The flex pipe was last replaced 4 years ago and it developed a small hole. They replaced the whole pipe this time from manifold to catcon.
The windshield was quite pitted as it could very well be the original and the week before developed a stress crack on the drivers side edge. Not sure what that is all about. It's nice to have a clear windshield!
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 08-31-2015, 11:27 AM   #4458
87z16
did my radiator this weekend, was leaking from the seam, plastic/alum. followed richpins video, mostly, THANK YOU!!!
had issues with 2 bolts, the lower tranny cooler line and putting back the bolt holding the condensor on the drivers side.
well stripped the line and now im replacing upper and lower lines. after all they are original. they are ordered.
amazon seems to be cheapest for all this.
99 SL2 maroon/beige
99 SL2 maroon/black
tom
Old 09-02-2015, 05:45 PM   #4459
TheIrvMan
TheIrvMan is on a distinguished road
Removed a tonne of algae from the wiper fluid reservoir as it was clogging the pumps filter. I've had the car three months so the po must have been using cheap waterd down stuff. I then armor alled the dash. Latter I'm going to go get some silicone sealant to fix a leak in the trunk. Nothing major for now.
TheIrvMan is offline   Reply With Quote
Old 09-09-2015, 02:04 AM   #4460
NWSaturn247
Added 8 ounces of MotorKote hyper lubricant to the transmission.
http://motorkote.com/32oz-motorkote-hyper-lubricant
1993 SL2 SOLD @189k
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
