Old 06-21-2015, 05:53 PM   #1
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
Default Please help guys!!!
I swear two days ago the car was fine today I get in the Security Light warning lamp on the cluster is on steady, Car starts up but when I shift into gear the service wrench illuminates, The dome lights when I turn the key to the on position blink like a strobe light and stay on as normal when the ignition is off, The DRL lights are disabled and the A/C is disabled as well, My coolant and gas gauge are inop as well, Tach and speedo work as they should, The door buzzer when the door is open also acts crazy when the ignition is turned on as well but returns to normal when the ignition is turned off, The instrument panel lights on the dash when the lights are turned on blink like the dome lamps as well, Also my RKE remote does not work at all now either, I have no idea what is wrong the whole car acts as if it has a short, I tried disconnecting the Battery and reconnecting it only for the car to act the same, I removed the PCM B fuse as well with no help there. PLEASE HELP!!!
CHECK YOUR OIL!
Old 06-21-2015, 07:34 PM   #2
billr
Default Re: Please help guys!!!
No trouble-codes set or pending?
Old 06-21-2015, 07:41 PM   #3
cdxhizors
cdxhizors has a spectacular aura aboutcdxhizors has a spectacular aura about
1999 SW2
2002 L-Series 2.2L Sedan
This can't be related to the pink/red hot wire in the fuse panel.. F5 I think? Can it? I know usually when it goes bad it causes loss of most of these things. What if it's loose?
cdxhizors is offline   Reply With Quote
Old 06-21-2015, 07:52 PM   #4
Pretty sure F5 is a 2nd gen pin, not a 3rd gen...so no it isn't F5. Think it's like B52 or something...lol
It's some kind of electrical problem, easiest thing to try is spending 10-20 minutes checking every fuse for a blown one.
Old 06-21-2015, 11:00 PM   #5
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
I have not checked for codes, The BCM appears to have gone bad, I have no idea how Im going to find a compatible unit much less have accurate mileage, Its ashame the cars in such good shape.
CHECK YOUR OIL!
All Right Guys You Have To Look Here !!!!! pclear9061 Ion Mods 22 09-21-2007 08:32 PM
what you guys think?????? rapidion Ion Mods 9 12-25-2006 01:33 PM
Thank you guys! blsman S-Series General 0 11-18-2005 07:40 PM
You Vue Guys My Like This Pic getz999 Vue Red Line 10 10-26-2005 03:48 AM
