Old 10-10-2008, 05:11 AM   #1
Richie V6
Richie V6 is on a distinguished road
Dizzy Odd Engine Questions
Hello guys, I was wondering if anyone has ever torn down a Vue engine to have a look inside. I am hoping the Vue Redline has a MDX motor which has a forged crank and rods opposed to a Odyssey motor which does not. I have been digging around trying to find a clear answer what Honda motor they actually used in the Vue Redline. In 2003 the MDX upgraded to a motor with 265hp (J35A5) which was really 253hp after the everything went SAE. I am pretty sure GM uses all SAE measurements so the L66 is pretty close to the MDX (J35A5). The L66 was released in 2004 (correct me if I am wrong) while the Odyssey did not get a new motor until 2005 going from J35A4 to J35A6. While the Odyssey was rated for 255hp from the factory it fell to 244whp after SAE standards. Does anyone know if all the Vue Redlines came with AWD. I am pretty sure Honda uses the forged internals for all the AWD versions of the J35. I was hoping to use the internals from a Vue engine to stroke my 3.0 Accord engine (J30A4) to a 3.3.
Richie V6 is offline   Reply With Quote
Old 10-10-2008, 08:16 AM   #2
cleblanc92
cleblanc92 is on a distinguished road
cleblanc92's Avatar
2004 VUE Red Line
Default Re: Odd Engine Questions
Originally Posted by Richie V6 View Post
... Does anyone know if all the Vue Redlines came with AWD. I am pretty sure Honda uses the forged internals for all the AWD versions of the J35...
My '04 RL is not AWD. Good luck with your other research!
'04 RL / K&N Intake / Curt Hitch / AUX via FM Modulator
...I survived...the VUE survived...the deer, well, not so much.
cleblanc92 is offline   Reply With Quote
Old 10-10-2008, 01:12 PM   #3
fotovue
fotovue will become famous soon enough
fotovue's Avatar
2007 VUE Red Line
http://www.saturnfans.com/forums/sho...244#post764244
from the Pilot, & Odyssey
different websites list different numbers, either J35A3, J35A4, J35A5, J35A6, or J35A9 depending on which website you look at. Some say it is the same engine with the ridgeline, odyssey, pilot, and mdx, however i believe this is faulty information perhaps stemming from the occasional reference to the engine as "J35A" only, not the full designation. As far as I can tell, we have the J35A4 from 2003-2007.
GM states in a few reference sites that is the L66/J35A4 for 2004-2007.
2004-2007: 6Cyl 3.5L GAS, FI, SOHC Engine, Engine Code "J35A4", With MFI Red Line
2004-2007: 6Cyl 3.5L GAS, FI, VIN "4", SOHC Engine, Engine Code "J35A4", With MFI Base
2004 RL VUE AWD Black *R.I.P. 07/01/06* 65k
The 1st sold, 49th built
2007 RL VUE FWD Black *Born 01/26/07* 100k
mods: 4 wheel disc brakes, window tint, spoiler, blues and twos
fotovue is offline   Reply With Quote
Old 10-10-2008, 01:37 PM   #4
Richie V6
Do you know if the L66 has its exhaust runners casted into the head that connect 2 precats? The J35A4 still used exhaust manifolds that connect the 3 ports from each head. This is a pictures of the J35A4 from a 02-04 Odyssey.
Old 10-10-2008, 06:14 PM   #5
burnout
burnout is on a distinguished road
burnout's Avatar
The "forged internals" question in regards to AWD is a myth. The engines aren't changed between FWD and AWD models, just the transfer cases attached to the transmissions...
That engine looks to be very old, probably pre-2004 if I had to guess. The cast in header was a later model thing, and all V6 Vues have it.
Has anybody been able to go and find the block casting on their vue to see if it is just J35A or J35A4? ... or possibly something else?
'13 VW CC 2.0T
'99 Volvo S70 AWD
burnout is offline   Reply With Quote
Old 10-12-2008, 12:56 AM   #6
Richie V6
I was talking about the FWD Honda/Acura models that used weaker internals. Thanks to fotovue its seems that the Vue Redline uses the same connecting rods and crankshaft as the Odyssey. Which are cast iron instead of forged steel.
Odd engine sound. MacG S-Series Tech 2 05-21-2009 10:48 AM
odd engine sound.. briansc1 S-Series Tech 3 07-24-2008 06:02 AM
Odd new engine vibration ken b. S-Series General 4 01-02-2007 01:11 PM
Oil filter questions (odd ones) Alex C S-Series General 1 06-19-2005 09:15 AM
odd engine reaction during acceleration ZuGG S-Series Tech 14 11-22-2002 05:10 PM
