Old 09-19-2008, 10:54 PM   #1
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Default OEM Tail Lights are now smoking...
I smoked my OEM tail lights and kept my Altezza Carbon Fibre tails as backups. They came out great. I used Testors Transparent window tint paint that FGCA_XRL recommended. I found out that you don't need to mask off the backup light windows, just make a single light pass over this area. I used about 3 light coats and they look good.
I'm going to wax them up some more and get them to match the black body. The surface mounted led lamps I have in them are brighter than the OEM incandescent bulbs.
Sorry for the VUE not being perfectly clean, but the past few weeks dodging hurricanes has been hectic...
I can recommend to everyone using the Testors to smoke their tails... No clear coat is necessary with this paint.
http://www3.towerhobbies.com/cgi-bin...1p?&I=TESR2949
Thanks again FGCA_XRL.
2006 Black VUE Red Line - Now running iOS 11
Old 09-19-2008, 11:18 PM   #2
FGCA_XRL
FGCA_XRL will become famous soon enough
2004 VUE Red Line
Default Re: OEM Tail Lights are now smoking...
Looks awesome man. Now you have to do the 3rd brake light too! 1 T15 on each side the the spray nozzle pulls off. You have to kinda angle it out. And the reflectors too, they pop out from the back IIRC. Those I did with actual window tint on mine so it was easy. You could just mask the bumper off if you wanted to I suppose.
I started tinting my gf's car. She wanted it to be lighter than mine at first, but they're too light so I think I'm going to make them way dark.
FGCA_XRL is offline   Reply With Quote
Old 09-20-2008, 01:37 AM   #3
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Comparing the tail lights to the center brake light you can see how much of the red color disappeared. The Testors tint paint worked like a charm!
It really wasn't hard to do, especially after I discovered you did not need to mask the backup lens, just spray over it once...
Old 09-20-2008, 01:20 PM   #4
FGCA_XRL
2004 VUE Red Line
I masked it for good measure. I've seen many people spray over it as part of the light a black it out too, I didn't want that.
Old 09-20-2008, 02:50 PM   #5
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
You'll be surprised how the clear survives. I sprayed one coat over mine and they did just fine. I did have the masked for the first two coats.
Amendment...
I recommend masking them for the first two coats and then do a final third coat over the entire tail light, not concentrating on the clear lens.
Old 09-20-2008, 09:03 PM   #6
burnout
burnout is on a distinguished road
burnout's Avatar
Loving it!
'13 VW CC 2.0T
'99 Volvo S70 AWD
burnout is offline   Reply With Quote
Old 09-21-2008, 10:23 AM   #7
phatbasterd
phatbasterd is on a distinguished road
2005 VUE 3.5L
Looks hot. Can you tell me what bulbs you are using tho. Thanks
phatbasterd is offline   Reply With Quote
Old 09-21-2008, 11:50 AM   #8
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__2-RED-SMT-27-LED-BRAKE-TURN-TAILLIGHT-BULBS-3157-3156_W0QQitemZ280267299277QQadnZCarQ20Q26Q20TruckQ 20PartsQ20Q26Q20AccessoriesQQadiZ2865QQcmdZViewIte m?hash=item280267299277&_trkparms=72%3A543|39%3A1| 65%3A12|240%3A1318&_trksid=p4506.c0.m245
They use surface mounted led's and are very bright, brighter than the incadescent bulbs. I've been using them for 2 months with no problems.
SMT LED Bulbs
Impress all your friends with our all new "SMT" LED's. Surface Mount Technology is the latest in LED design. It's High Ouput combined with an even spread of light makes this bulb perfect for all applications. It has 21 radial firing LED's that fire perfectly into the chrome reflectors of your cars lamp assembly, and 6 Forward firing LED's to fill out the front of the lens. This light bulb is the best LED replacement on the market!
Clean N' Clear
Replace your ugly filament bulbs! LEDs and Housing are clear when lights are off.
Vivid Color
Replace your dull filament bulbs! Color comes alive with V-LED
Old 09-21-2008, 02:36 PM   #9
phatbasterd
2005 VUE 3.5L
The brightness in the stock housing is just as good as the tyc's? Ive tried diffrent led bulbs in the stocks and have not had any good results
Old 09-21-2008, 02:58 PM   #10
OhioVueBoy
OhioVueBoy has a spectacular aura aboutOhioVueBoy has a spectacular aura aboutOhioVueBoy has a spectacular aura about
OhioVueBoy's Avatar
Location: N. Bethesda, Maryland (DC) (Dayton Ohio Native)
2002 VUE 2.2L
Do these require any resisitors as well?
I tried LEDs once in the VUE... didn't work so well for me. Xenons and full exterior LEDs are on the books for the smart though... so I'm looking for some good bulbs.
~D.J.~
2012 Mercedes Benz C250 Sport Sedan
2008 smart fortwo Passion Coupe 8/28/2008 - 3/12/2012
2002 VUE FWD4m - Gone but not forgotten. 5/14/2002 - 10/31/2011
OhioVueBoy is offline   Reply With Quote
Old 09-21-2008, 03:07 PM   #11
FGCA_XRL
2004 VUE Red Line
Most of them will have resistors supplied inside the bulbs nowdays.
Old 09-21-2008, 03:20 PM   #12
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
~D.J.~
No resistors are needed as long as the front incandescents are used. The front lamps offer enough of a load to keep the flasher blinking normal.
These surface mounted led lamps are the only ones bright enough to replace the OEM bulbs. I tried the other ones also, and they don't compare.
With the speed of the led's illuminating, it gives a car a little more of a safety edge when you hit the brakes. This is why the Aura has them for the brake lights.
Old 09-21-2008, 03:27 PM   #13
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Originally Posted by phatbasterd View Post
The brightness in the stock housing is just as good as the tyc's? Ive tried different led bulbs in the stocks and have not had any good results
Yes, these led lamps look really good in the TYC's. Because of the clear red lenses you can see the led assy well. These surface mounted leds lamps are night and day with the regular led lamps.
Old 09-21-2008, 07:24 PM   #14
YourMainParadox
YourMainParadox is on a distinguished road
YourMainParadox's Avatar
2004 VUE 2.2L
expensive tho.
YourMainParadox is offline   Reply With Quote
Old 09-27-2008, 10:22 PM   #15
phatbasterd
2005 VUE 3.5L
Does it say Enamel or Lacquer on your can the 2949 can i have is a lacquer and will not stick to the lights. It wipes off easily even after an hour of drying no matter how much i prepped it.
Old 09-27-2008, 11:17 PM   #16
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
It's enamel. I checked the website again.
I had no problems having it stick to the taillights. I even waxed them once and had not problems.
Take some sandpaper and give them a good sanding, 800 grit or more coarse. The scratches will disappear with one coat of the tint.
Old 09-30-2008, 11:26 AM   #17
phatbasterd
2005 VUE 3.5L
I hit them with a pretty good sanding but stilla no go. I ordered a can off the site you posted to see if it comes in a n enamel instead of the lacquer. The hobby shop i got mine from had the right number but said lacquer on my can so i have to wait till the other paint arrives then i ll give it another go.
Old 10-01-2008, 01:45 AM   #18
Counterfit
Counterfit is on a distinguished road
Counterfit's Avatar
Love the tails and the piece that houses the license plate lights but the Vtec is pretty ghey. Overall very nice though.
I'm with CoCo !
Counterfit is offline   Reply With Quote
Old 08-01-2009, 09:21 PM   #19
xtremeranger
xtremeranger is on a distinguished road
xtremeranger's Avatar
2005 VUE Red Line
2006 ION Red Line
DAmn Bobby, I just came across this thread....those look gooooood!!!!! may have to do mine now!!
What kinda LEDs do you have in your LP lights?
2005 VUE Red Line AWD - Tint, Audio, K&N
2006 ION Red Line Competition Package - Stage 2, strut bar, Hurst, Antenna delete, tinted corners, painted headlights
1998 SL2 - SOLD 87K-113K
xtremeranger is offline   Reply With Quote
Old 01-26-2010, 12:21 AM   #20
kingraven92
kingraven92 is on a distinguished road
2004 VUE 3.5L
Looks great man. Will it be too dark to see braking if you spray with the stock brake light bulbs in?
Thanks
kingraven92 is offline   Reply With Quote
anyone need OEM tail lights? kevo420 Vue General 4 04-22-2009 02:16 PM
clear tail lights and black tail lights on ebay cheap ericblkredline Vue Mods 5 08-28-2008 03:08 PM
VUE OEM Tail lights SaturnVue'03 Vue General 0 07-20-2006 04:57 PM
Bye Bye OEM Tail lights GirlWithAVue Vue General 39 01-23-2006 11:38 AM
Smoking out the tail lights? zeemo13 Mods and Performance 4 04-18-2005 07:54 PM
