Old 11-23-2009, 06:29 PM   #1
jeffff
jeffff is on a distinguished road
Default 04 AWD Redline.....squeaky front springs??
I own a 04 AWD Redline with 45000 miles. There is a wicked creaking/squeaky noise coming from the front, I'm assuming it's the springs as it only occurs when going over a bump.
Any of you experience this before? or have any suggestions as to what could be causing the problem?
Appreciate any advice.
jeffff is offline   Reply With Quote
Old 11-23-2009, 06:39 PM   #2
XRL
XRL will become famous soon enoughXRL will become famous soon enough
XRL's Avatar
2004 VUE Red Line
Default Re: 04 AWD Redline.....squeaky front springs??
Strut mounts.
XRL is offline   Reply With Quote
Old 11-23-2009, 07:00 PM   #3
jeffff
Originally Posted by XRL View Post
Strut mounts.
makes sense......easy fix?, whats involved?
Old 11-24-2009, 10:10 AM   #4
docderek05
docderek05 is on a distinguished road
2005 VUE Red Line
Jeffff,
find the replacement parts at your local auto store, left hand and right hand,
for your year.
Jack it up..block it up and remove your wheels or a side at a time, whatever you prefer. when you do, you will see where the strut links are mounted easily, but removing them might be a bee-atch without an impact driver to break em free as they are torqued pretty good..a cannot remember the spec, but once you have them loosened, you will have to place a metric allen wrench in the shaft of the link bolt, for each end, and back them off with a box wrench, 19 mm I believe,..the link bolt is designed like that to keep you from twisting the grease boot, and tearing it..take off top and bottom, clean up your mounting points, and grab the new part for that side of the truck, and again..you have to be diligent to hold that shaft on the reinstall, to make sure you do not twist the grease boot all to hell when you are re-installing the links. get the torque spec from the box of your new part, and once you have em tight with the box wrench, and the allen key for holding is no longer needed, torque down the nuts to the correct spec. all toll, this should take you about 1/2 hour a side, very simple, when you take your old links out..try to see if they move freely...you will find that they bind and creak and groan and lock up, and there goes your problem! A lot of folks here have done this job, some say that the replacement aftermarket links are bad, I have used them from Advanced Auto and so far about 15k miles since the change I have no complaints, they were about 35 bucks a side. If you are not comfortable with aftermarket, I guess the dealer would have em, but I am not sure what the price would be. This is very straight forward, and it should be simple with the correct tools. Best Regards, Doc
docderek05 is offline   Reply With Quote
squeaky front passenger side wheel bbcac S-Series Tech 1 10-21-2009 03:18 PM
Preferred front hub for 06 Redline AWD hein Vue Tech 1 09-21-2009 04:36 PM
2007 Vue Squeaky front suspension greensaturn Vue General 7 07-16-2007 07:47 AM
Squeaky noise in front left tire Thelonius S-Series General 5 05-16-2007 01:06 PM
Squeaky front shocks? leftlaneloony Ion General 45 11-27-2003 10:35 PM
