#1 |
![]() Join Date: Dec 2006
I have a 2001 Saturn L200 Sedan with about 52k miles on it. The car has developed a pretty bad vibration above 45MPH while accelerating. Once I let of the throttle the vibration goes away. I checked the CV boots, and I don't see any cracks or tares in them.
Does anyone know what might be causing the problem? thanks |
#2 |
![]() ![]() ![]() ![]() Join Date: Aug 2001
2007 AURA XR
2008 Astra XE
Any number of things.
Bad balanced tires. (cheap fix) Out of alignment. Bent rim. Tread seperating. The L-Series are known for vibration problems. A shim kit may be required to properly align the car. Do a search here under "vibration." BTW, welcome to the forums. ![]()
93 SW2 96 SL2 01 SL2 02 L200 08 Astra Xe 07 Aura XR Complacency leads to mediocrity. Mediocrity leads to our demise. |
#3 |
![]() Join Date: Jul 2003
2008 Astra XR
2002 L-Series 2.2L Sedan
Yeah, I've had similar problems. A wheel balancing fixed it right up. $20 at the dealer.
The family: 1993 SL2: 051,000 mi (!) 1996 SL2: 260,000 mi (sold) 2001 SL2: 98,000 mi 2002 L200: 215,000 mi 2006 VUE: 50,000 mi (sold) 2007 Ranger: 40,000 mi 2008 Astra: 161,000 mi |
#4 |
Thank you both for your quick replies.
I got new tires about 3 - 4k miles ago, so they were recently balanced, but I guess it's possible that a weight fell off. But what makes me think that tire balance isn't the issue is that I can get the car up to 75MPH, then let off the throttle and the vibration is gone. I would think that if a tire is out of balance or a rim is bent, the vibration would be there on or off throttle. I think I might have the alignment checked. Thanks. |
#5 |
I just went through the exact same thing with my 01 L200. It turned out that the CV boot was fine, except for a very small (less than half inch) tear in the back of the insided boot. This had let out just enough grease to run one of the three bearings dry. In order to find the tear, I had to pull the whole shaft. Luckily, I work for a string of salvage yards, and had a used shaft delivered to the house that day for $25. I'm sure you could find one similarly priced in your neighborhood, and the replacement is ridiculously simple.
Aaron |
#6 |
![]() Join Date: Nov 2000
2001 L-Series 2.2L Sedan
Being that your vibration starts at around 45 mph and only seems to occurr during acceleration, I would look at the motor mounts. I bet that is your problem. 52k miles is a little early for that problem to set in, however. Have them checked.
#7 |
![]() Join Date: Sep 2006
I have the same exact car with the same exact problem of vibration. I jacked up the car and noticed the motor actually moves back and forth when spinning the front wheels forward in back. I am guessing that the engine should not move back that easy. Are engine mounts a known issue with the L-series? What mounts should be replaced? I also noticed more vibration from the muffler lately not sure if this is related.
My Car: 2001 L200 2.2L with 110,000K on it. |
#8 |
Bump.
Has anyone replaced motor mounts on an L series. What do you look for? |
#9 |
![]() Join Date: Jul 2020
Does anyone have a video or advice on changing all motor mounts on a 2000 L-series Saturn?
#10 | |
![]() Quote:
you can inspect the cv axles by jacking up the front of the car (both wheels off the ground) and putting it in gear with the engine running. the cv axles should turn nice and smoothly with no runout, if there's runout (wobbling back and forth) there's your problem.
rings-1996 sl2 ~215k mi phoebe-1995 sl1 ~250k mi janus-2000 sohc2 ~190k mi tethys-1994 sw2 ~302k mi rip mimas-wrecked 1996 sw1-trailer pandora-1999 sc2 dione-1998 sw2 penny [iapetus]-1997 sw2 |
#11 |
![]() ![]() ![]() ![]() Join Date: Sep 2018
2000 L-Series 3.0L Sedan
Rotate your tires and see if the vibration problem changes.
#12 |
What model Saturn do you have? Please specify the engine size and transmission type.
374K miles - Holy canolli! Biden/Harris predictions, '21 -'25: weak economy; weaker military; more terrorism; emboldened RED CHINA. Sadly, B & H are proving me correct...too bad... now Russia?! |
Bookmarks |
L200 Vibration at 60mph | sketch | L-Series General | 38 | 03-23-2013 08:25 PM |
Vibration when accelerating | djwirthless | L-Series Tech | 4 | 03-13-2008 11:31 AM |
Vibration when accelerating | Bobhasfun | Vue Tech | 5 | 11-15-2005 07:39 PM |
AWD Vibration while accelerating | Druce | Vue General | 8 | 09-09-2004 08:27 AM |
L200- dash sympathetic vibration- help? | lewis2 | L-Series Tech | 4 | 02-13-2004 08:58 AM |
