Old 01-22-2022, 08:55 PM   #1
Chaz9496
Chaz9496 is just really niceChaz9496 is just really niceChaz9496 is just really niceChaz9496 is just really nice
Default Lower Intake Not Able To Lift Out
I'm trying to replace the thermostat on my LS2, sorry, I havent updated my vehicle yet in my profile, and can't get the lower intake out. There's no room to pull the rear intake runner tubes off to lift it out. The video on it and the valve cover gasket replacement edit that part out, so I have no idea how to lift out the rear without it hitting the front of the head. My Chiltons manual is worthless on this repair. How does this come out ? I did not remove the fuel rail. That may be why.
Old 01-23-2022, 11:36 AM   #2
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
Default Re: Lower Intake Not Able To Lift Out
Can you share a couple of photos ? I am not sure I understand what you are referring to.
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
lrbraner is offline   Reply With Quote
Old 01-23-2022, 03:34 PM   #3
Chaz9496
I put everything back together. I wasn't taking the chance of not having a car for a week. I'll just have to fork-over the 400 to have it done, maybe next season. I've spent too much on it already since last year when I got it.
Old 01-24-2022, 04:12 PM   #4
Rj 2000 LS2
Rj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really nice
2000 L-Series 3.0L Sedan
It sounds to me you were trying to remove the lower intake without taking everything above off first. I detailed how to remove these items a while back. It took me days to do it, weeks to figure out what to fix and weeks to repair it. In the end, I ruptured an intake hose which threw me for a loop. Removing all the intake components is complicated and exhausting. There are bolts in most inaccessible locations and everything origami's together. You are doing the right thing having someone do the work for you. However, be prepared for other repairs to pop up. They will likely recommend cam cover gaskets and other repairs. Be prepared for the onslaught.
Rj 2000 LS2 is offline   Reply With Quote
Intake cam lift? SlushWagon S-Series Tech 14 01-19-2019 02:47 PM
Unable to remove lower intake manifold on 2004 Vue 3.5 V6 WorldTour Vue Tech 3 10-14-2018 02:28 PM
Need Help! Accidentally Over Torqued Lower Intake Manifold to Spacer! DTMartin L-Series Tech 5 12-10-2016 02:10 AM
Lift points on SC? And is 15 5/8 lift enough to clear rhino ramps? curls S-Series General 27 02-05-2012 11:24 PM
Dohc intake cam, same lift for all years? Modding_out S-Series Mods 1 10-17-2011 12:56 PM
