Old 02-19-2022, 12:27 PM   #21
Rj 2000 LS2
Rj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really nice
2000 L-Series 3.0L Sedan
Default Re: New Thermostat Replacement, Still Only Running At 180 Degrees. Why ?!
The entire behavior of the coolant system depends on the input from the temperature sensor. It could be indicating the engine is hot and it is not. Have you ever seen a PO128 code?
Running down the highway at 207-210 degrees dakota1820 S-Series Tech 12 06-27-2019 01:30 PM
'97 SC2 running hot- thermostat?? Andrewd67 S-Series Tech 6 10-31-2013 08:50 PM
sl2 5 degrees out car running baddddd livingproofofit S-Series Tech 58 01-24-2009 04:47 PM
sl2 5 degrees out car running baddddd livingproofofit S-Series Tech 1 01-16-2009 10:53 AM
Thermostat change / was running cold DonP S-Series Tech 1 06-11-2006 02:22 PM
