Old 09-29-2021, 02:33 PM   #1
captbridgers
captbridgers is on a distinguished road
2001 L-Series 3.0L Sedan
Dizzy Now what do I do?
I have a 2001 Saturn L300, 3.0. It will start up...no problem...the moment I take foot off gas & reach to shifter, it dies. A friend suggested it is a vacuum leak.
HELP ME! PLEASE!
captbridgers is offline   Reply With Quote
Old 09-29-2021, 02:52 PM   #2
crosscountryLs1
crosscountryLs1 is on a distinguished road
Default Re: Now what do I do?
I had an issue with a fuel pump that started to act similar, but I would pressure test the fuel line first. Pull the codes you are getting.
crosscountryLs1 is offline   Reply With Quote
Old 09-29-2021, 04:01 PM   #3
captbridgers
I don't know if my reply went thru but Many Thanks !
Old 10-10-2021, 02:16 AM   #4
pierrot
pierrot's Avatar
Originally Posted by captbridgers View Post
I have a 2001 Saturn L300, 3.0. It will start up...no problem...the moment I take foot off gas & reach to shifter, it dies. A friend suggested it is a vacuum leak...
1) What is the vehicle maintenance history and mileage?
2) What is your normal routine in starting your car's engine?
3) At what point have you depressed the accelerator pedal prior to moving the shift selector? 3.1) Is there a reason why you need to this?
361K miles - Holy canolli!
Biden/Harris predictions, '21 -'25: weak economy; weakened military; increased terrorism; an emboldened RED CHINA. Sadly, B & H are proving me correct...too bad.
Old 10-11-2021, 01:42 AM   #5
pierrot
pierrot's Avatar
Originally Posted by pierrot View Post
...3.1) Is there a reason why you need to this?...
Correction - Is there a reason why you need to do this?
