Old 09-19-2021, 10:33 AM   #1
PLHorton
PLHorton is on a distinguished road
2002 L-Series 2.2L Wagon
Default AC compressor not running
I have 12v at the compressor but it won’t engage. It there something else it needs besides the 12v? Inter lock or disable circuit? I can only see the 12v harness going to it. It there more?
Thx
Phil
PLHorton is offline   Reply With Quote
Old 09-19-2021, 11:27 AM   #2
02 LW300
02 LW300's Avatar
Default Re: AC compressor not running
If you have 12+ and ground at the compressor the coil in the clutch has failed. I have replaced several on these cars over the years. I have owned seven of these cars and still run three in my family.
2002 L200/5 Loaded, over 1/4 million miles!
02 LW300 is online now   Reply With Quote
Old 09-19-2021, 10:05 PM   #3
puckhead
puckhead is on a distinguished road
buy a new clutch, or do this:
http://www.saturnfans.com/forums/sho...d.php?t=172866
i used a piece of mig welding wire in place of the fuse.
puckhead is offline   Reply With Quote
Old 09-19-2021, 10:26 PM   #4
I have looked into removing the clutch assembly on my L-Series car, but found it unworkable. The distance between the clutch and frame rail is too close to get tools in place to perform that work. I was unable to see any way of removing the clutch without disconnecting the compressor and removing it from the engine compartment. If one dismounted the compressor while keeping the lines connected it still means there is a significant problem to overcome to pull the clutch off of the compressor shaft. Additionally, when reinstalling the clutch one must re-gap the clutch surfaces, and they won't tolerate an inaccurate gapping. The clutch is engaged electromagnetically. A gap which is too wide or too narrow will result in improper operation of the clutch and therefore a compressor which won't work.
361K miles - Holy canolli!
Biden/Harris predictions, '21 -'25: weak economy; weakened military; increased terrorism; an emboldened RED CHINA. Sadly, B & H are proving me correct...too bad.
Dash shows Engine running at reduced power and running rough SatOut09 Outlook General 1 02-23-2021 04:52 AM
AC compressor oil leak = compressor seize? 2003vue Vue Tech 10 01-24-2013 05:54 PM
A/C Compressor Question: Is my compressor bad? TIMSPEED S-Series Tech 8 04-18-2009 12:03 AM
A/C Compressor kansasfarmer L-Series General 8 06-19-2007 09:03 AM
My SC2 is running bad, running ruff under a load :( DeMAN S-Series General 7 06-29-2005 12:13 AM
