#1 |
![]() Join Date: Apr 2010
I hope everyone is having a great week during the holidays,
I just acquired a 1997 Saturn SL2 dohc 5 spd from my bossman and it runs like a champ. Engine is very strong, 2nd gear kind of grinds a little when shifting, but other than that, I love it. Now the problem is, when I accelerate at any given time, it feels as though the gas pedal has a rusty feeling to it when pushed down. Sometimes while in motion when I push on the pedal, it kind of jolts the car because it has a little sticky feeling. Now before I rush and pour WD40 all over the pedal / cables..etc and end up breaking something, I wanted to get some communicty input. ![]() Any help is greatly appreciated. Happy New Years! |
#2 |
I would do a visual inspection first. Look to see if it is rubbing against something, both on the interior side and in the engine compartment. There should be no reason to spray any gunk on it.
92 SL1 original owner 94 SL2 Homecoming 98 SC2 White Hot 02 SC2 |
#3 |
Read over the sticky in the General forum
Using the links there or going to YouTube and finding the video by richpin06a, find his video on throttle body cleaning. Remove and carefully clean the back and inside of the throttle body with carb cleaner. You will be amazed at how gunked up it is. The gunk gets on the throttle plate edges and pivot and makes it feel sticky at the pedal. If I'm wrong, cost = $0 ![]()
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#4 |
![]() Join Date: Oct 2011
Both our SL2s had this, problem was cured by cleaning the throttle body. Check the Richpin video as mentioned, also stickied in the HowTo Library.
You start spraying lube on the cable you'll just attract grit which Will then jam the cable. -LR |
#5 |
Although the full Throttle Body cleaning is a good idea; I bet you could just spray carb cleaner into the mouth of the TB around the pivots while exercising the throttle and resolve this issue.
-Robert |
#6 |
True Robert but from my experience.. not for long. I tried a shortcut cleaning the first time and a little while later the IAC started sticking as well. It's not all that much more work to pull the TB and clean it completely.
1997 - SL2, barebones, 161k, Auto - Rebuild complete and.. burnt a valve 20k later Arrgh! Purchased 114k 10/07 Added OEM CC |
#7 |
#8 |
WD40 is somewhere around 20 percent oil. And the last I checked, oil is a lubricant.
![]() As for the original question, I agree most likely the throttle body. Once you disconnect the cable you can verify that the cable and/or pedal isn't binding. From there take your pick of how to clean the throttle body. I've never had the throttle body off our car, but have cleaned it quickly from the outside a couple of times and have never had any sticking issues since the first cleaning. |
#9 | |
![]() Quote:
#10 |
![]() Join Date: Dec 2001
2002 VUE 3.0L
I can vouch for that - go for it!!
02 VUE Auto AWD-63k-Florida 02 SL2 Manual -76K, Germany 00 SL2 Auto-90K-failed emissions, Portland, OR 99 SL2 Auto-115K-aging, Portland, OR 91 SL1-Stolen 03, 113K 96 SL1-Totaled 02, 86K |
#11 | |
![]() Join Date: Jun 2007
![]() Quote:
^^^^^^^+1 ![]() I would never recommend using WD40 ON ANYTHING on vehicles. Mainly cause there are other safer alternatives and to use whats designed for it.
2002 SL2 115k "Whisper" No leaks!! :) 115 and going strong.. |
#12 |
And the goal is not to lubricate the TB it's to clean it. WD-40 attracts debris which is why it is seldom used today. Best light lube today is tri-flow.
#13 |
![]() Join Date: Aug 2007
1998 SW2
1998 SW1
Do the TB cleaning. It can only help even if it does not fix the problem (which it probably will). This is now a yearly or even bi-yearly practice for me on both SW's. I even have extra TB's on hand that are already clean from the JY to swap in so it does not take any time at all when it needs to be done. Then I can clean the dirty ones at my leisure for the next swap. It is a 5 minute job to swap. 15 minutes if you actually have to clean it and put it back on. I sometimes take more time just because I am picky at how clean it gets. I do the same thing with the EGR valves.
1998 SW1 (wife's car) 1998 SW2 (Winter daily driver) 2004 Vibe GT (summer daily driver) |
Bookmarks |
My car dies when the brake pedal is pushed | weisserguy | S-Series Tech | 12 | 02-11-2009 02:52 AM |
SW2 dies when brake is pushed | dogginfox | S-Series Tech | 10 | 07-28-2008 06:28 PM |
feels like pulsing pedal..(no abs) | saturn94v | S-Series Tech | 4 | 04-17-2008 11:03 AM |
Brake pedal feels weird | Dan76 | S-Series Tech | 1 | 04-21-2007 09:20 AM |
totalled? front pushed in! | sc2_94 | S-Series Tech | 6 | 10-17-2002 02:05 AM |
