Old 06-04-2007, 03:57 AM   #1
roger46982
roger46982 is on a distinguished road
Default Power windows quit!!!
I have a 04 Ion that the power windows have quit working on, all of them quit at the same time. Help!!!
roger46982 is offline   Reply With Quote
Old 06-04-2007, 07:04 AM   #2
Default Re: Power windows quit!!!
Fuse(s).....................
VCX NANO
Old 06-04-2007, 11:24 AM   #3
roger46982
Fuses OK.
Old 06-04-2007, 09:11 PM   #4
Do they all share a common ground?
VCX NANO
Old 06-04-2007, 09:37 PM   #5
ssicarman
ssicarman's Avatar
If the power window fuse in the incar fuse block is good then the next check would be to see if you have power to the power window switch. A better first check woul dbe to see how many broken wire you have in the wiring harness from the body to the door.
Open the door and pull back the rubber boot. It should come off of the body. The door side may be taped to the wiring harness and not come out/off. I suspect that you will find a few broken wires.
Old 06-05-2007, 02:15 AM   #6
roger46982
I will check out the wires closer and see what I have.
Manual Power Locks/Windows swap to Powered Locks/Windows/Keyless Entry Dreamimage S-Series Mods 20 12-03-2012 12:14 PM
1996 Saturn SL2's Power Windows quit working DiabloDan S-Series General 13 04-13-2010 06:36 AM
manual windows to power windows swap mushusdad S-Series General 3 02-04-2008 05:08 PM
How Difficult to Install Power Windows on a car with Power Locks? sandybright S-Series Tech 1 09-07-2006 04:25 PM
Manual windows to power windows M.Nguyen S-Series Tech 1 06-04-2004 08:25 AM
