View Poll Results: Thermostat Brands | |||
STANT |
6 | 54.55% |
OEM |
2 | 18.18% |
Autozone Brand |
2 | 18.18% |
NAPA Brand |
0 | 0% |
O'Reilly Brand |
0 | 0% |
ACDelco |
0 | 0% |
Gates |
1 | 9.09% |
Voters: 11. You may not vote on this poll |
Thread Tools | Display Modes |
![]() Join Date: Dec 2011
I have a 2000 Saturn SL SOHC 1.9L
I have searched around and read the 'checklist' but come up dry. I'm pretty sure I need a thermostat due to temp reading 1/4 all the time. I have replaced ECTS and still get 1/4 reading. The only other thing I need to replace is the intake manifold gasket but besides that I do not know which STAT # to get. 14279 or 35279? and does it come with a gasket/o-ring? thank you. |
![]() Join Date: Dec 2001
2002 VUE 3.0L
According to the checklist "It is recommended to replace this with a STANT 14279 188/195 degrees F thermostat."
02 VUE Auto AWD-63k-Florida 02 SL2 Manual -76K, Germany 00 SL2 Auto-90K-failed emissions, Portland, OR 99 SL2 Auto-115K-aging, Portland, OR 91 SL1-Stolen 03, 113K 96 SL1-Totaled 02, 86K |
#3 | |
![]() ![]() ![]() Join Date: Apr 2009
and yes, 14279 is what you need. Yeah, but most people have found that it's a smidge too big and it won't go in the groove properly (hence why I personally never replaced my gasket and there were no obvious leaks; YMMV). I believe you can order another gasket for the thermostat, though. No problem.
97 SL2 DOB: 3/19/97 Date Obtained: 5/30/07 Status: Alive, 1/2 exhaust 2004 Merc G.Marquis GS DOB: 2/4/04 Date Obtained: 7/6/12 Status: Alive, no heat |
The gasket is oversized by design. Set the 4 corners and then compress each side into the grove.
STANT 14279 for the thermostat. Not the CarQuest look alike... |
#5 |
Yes, I'm sure they design the ring to not fit in the groove just to create frustration and annoy buyers.
There is thread after thread of oversized O-rings beyond the size that can be forced into the groove. Likewise more than a few threads concerning the early failures in the Stant units that have to be replaced early in their life. A simple part such as a thermostat will likely never have 100% quality control, but when I see a trend of problems I move away. The "preferred" part seems to be one with a trend of problems. ![]() |
^^^ +1
2002 SL2 Manual - new in November, 2001 As of 09/30/17: 223,751 Miles - SOLD New owner report of 08/08/19: 234,408 Miles 2013 Mazda 3 HB - new in October 2012 As of 11/12/20: 78,895 Miles |
#7 |
Your complaining is out of date, no recent complaints. O-ring seems to fit just fine.
#8 |
![]() ![]() Join Date: Dec 2011
2002 SL1
I just replaced mine last week, The O ring did seem to be a bit oversized and wanted to pop out. However, a couple of dabs of silicaone to hold in place solved the issue.
2002 SL1 (55,000 km @ 11/12/2016) 2006 Chrysler 300C (modified) 2012 Hyundai Santa Fe 1999 Jeep Grand Cherokee |
#9 |
To seal properly it is supposed to be a tight fit against the outside edge of the recess. If you roll it in it will promptly roll back out. A couple spots of RTV will hold it in though as you explained above.
#10 |
agreed; heck alordofchaos and myself got the classic Stant syndrome -- broken or completely removed rubber seal in the part that goes into the housing!
In all fairness, it's the design of the thermostat itself, NOT Stant's fault. it is the reason why you hardly see thermostats designed like ours.
#11 | |
![]() How exactly do you find the corner of a circle? ![]() A quick search will show a fairly high number of Stant failures at short use periods, and plenty of improperly sized O-rings, along with a number of excuses why both occur. Personally I would buy anything that fits the stock housing other than the standard Stant unit everyone keeps buying. |
#12 | |
I'll be waiting.
#13 | |
For that matter most replacement thermostats fit in the stock housing, and I've yet to see anyone state early failures with other brands vs the Stants. |
#14 | |
#15 | |
Personally I'd just stay away from the ones the run real cool, regardless of what the brand. And if I had early failures with the NAPA or any other brand, warn everyone else with a post on the forums. A single failure is one thing, but if there is a trend within any specific brand or type it can be a red flag to anyone else. Some sites even claim the NAPA units are a Stant Superstat. I'm not sure if this is true of all NAPA units or not. I just know the unit I got is not of the same design as the Stant units people here tend to use, and it's worked fine. |
#16 |
Will red RTV be alright to hold in the o-ring gasket or do I need black?
I understand the thermostat should only go in one way, does the position need to be in specific direction, like some thermostats have the jiggle valve needing to be facing in the up in the 12 o'clock direction? Maybe this thermo doesn't have jiggle valve, idk. What is the thermostat housing torque specs? thank you all for this informative help, much appreciated. |
#17 | |
2002 SL2 Manual - new in November, 2001 As of 09/30/17: 223,751 Miles - SOLD New owner report of 08/08/19: 234,408 Miles 2013 Mazda 3 HB - new in October 2012 As of 11/12/20: 78,895 Miles Last edited by TXSaturn02; 12-31-2011 at 09:46 PM. |
#18 | |
#19 |
I didn't have a problem with the fitment of the O ring gasket on either of my Stants; first one done mid-08, I think, or the one a month or so ago
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#20 |
![]() ![]() Join Date: Nov 2010
Location: Pacifica by San Francisco – 5sp – Original engine rebuild as documented by this site @ 177K due to high oil consumption. Mpgs back to 40+. Car runs smooth, like a top. Now at 220k. Successful rebuild !
1996 SL2
I also did not have a problem with the O-ring on my Stant.
Suppose everybody used the Stants and nothing else. That would make it pretty dammed hard to catch complaints for any other thermostat. Point is, the Stants are the most popular IMHO... so of course "if" there are complaints, most likely it will be from the Stants. I have not noticed any complaint posts and if there are some, I would be taking things with a grain of salt as as many nubie DYIers screw up and not notice things or do things that would cause the units to fail or not operate properly. |
Bought new thermostat Saturn 2000 SL1 rated at 180*. Is this correct thermostat? | 1tallguy | S-Series Tech | 11 | 10-25-2011 09:55 PM |
2.2 Thermostat | emsvitil | Vue Tech | 4 | 08-03-2010 04:06 AM |
SES - Thermostat | TXSaturn02 | S-Series Tech | 9 | 01-21-2008 10:23 AM |
Thermostat? | Rapsack | S-Series Tech | 1 | 01-06-2008 02:42 PM |
Thermostat | RalliArt16 | S-Series Tech | 9 | 04-27-2005 08:16 AM |
