#1 |
![]() Join Date: Jul 2006
1996 SL1
Hi Folks,
Can the A/C low pressure Valve core be replaced without depressurizing the refrigerant? Thanks Michael |
#2 |
It may just need tightening instead of replacement in which case you'll lose refrigerant. It may help to refrain from posting more than once for the same topic as your orginal post will elicit any/all replies.
#3 |
![]() Join Date: Jun 2002
Ever change a tire valve core? The second you take it out, all the air will try to escape. It's exactly like that with the a/c valve core too.
85 GLH 367whp. http://www.saturnfans.com/forums/showthread.php?p=2261629#post2261629 00 Insight 72mpg |
#4 | |
![]() Join Date: Jun 2006
![]() Quote:
This is true but the colder it is the less pressure it will have to escape and in theory if you were at about 35 below zero, it would not leak at all while you were doing it because it would remain a liquid. |
#5 |
If you wait until the system temperature is -14degF, then you can do it. At that temperature, R134a has a pressure of just a tick above 0psig. any colder than that and the internal pressure will drop below atmospheric pressure, and the system will ingest air.
ideally, find someone with the right recovery equipment. |
Bookmarks |
Help with Heater Core | SaturnSSteach | S-Series Tech | 10 | 07-30-2011 12:42 AM |
Used Heater Core Okay? | Burgertime631 | S-Series Tech | 4 | 02-21-2007 01:46 PM |
Heater core | smellon888 | S-Series General | 1 | 10-01-2005 08:10 PM |
Heater Core?? | beensmoked | L-Series Tech | 2 | 12-30-2004 12:25 AM |
Evaporator core | sepulveda | S-Series Tech | 7 | 08-18-2004 08:43 AM |
