#1 |
How come you have them when you buy all-in-one struts but they're not available separately? Are these things actually available anywhere, or is it off to the pick and pull to get one of these?
#2 |
![]() ![]() Join Date: May 2004
I try Summit racing, Rock Auto, Parts Geek online...
then also ask at FLAPS, NAPA & Carquest/Advanced, or an independent shop. |
#3 |
I had hedged my bets. I went to a Pick 'N' Pull and grabbed the isolators on the front, as well as a pair of rear strut mounts that had the rubber. At the same time, I ordered two different sets of Energy Suspension coil spring isolators.
Turns out that the rears were unneccessary as the isolators are built into the rear strut mounts. The front isolators could've been made to work somehow with some trimming, but the scavenged original isolators worked a lot better. The SL is a lot less noisy now on low speed turns. |
#4 |
Are "isolators" = "strut mounts" ??
#5 |
Bookmarks |
coil spring | Cavell | Vue General | 0 | 03-08-2017 05:00 PM |
broken coil spring | scotttomlin | S-Series Tech | 14 | 07-17-2014 06:20 PM |
coil spring for a 2002 SL2 | ky saturn | S-Series Tech | 5 | 10-19-2010 03:51 PM |
coil spring re use??? | bendover817 | S-Series General | 2 | 08-17-2010 10:41 PM |
coil spring | culdri | L-Series Tech | 2 | 04-18-2009 04:29 PM |
