#1 |
![]() Join Date: Mar 2022
My 97 SL2 died while driving down the road. I've recently replaced battery, plugs, wires, and valve cover gaskets. Ran fine for about 10 miles then lights went dim, lost power and just died....?
#2 |
Serpentine belt and alternator?
Battery is only used to start the car. Once running, the alternator provides the power to keep the car running. If the belt breaks or alternator weakens/dies, the car can run on just the battery for a while Charge the battery, should start once charged - but will die again since the alternator is not recharging the battery. Some auto parts stores will test your alternator for free.
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#3 |
Codes?
#4 |
![]() ![]() Join Date: May 2004
So, uh nanajx6 -
fun replacing the alternator, yes? DB Electric is the way to go |
#5 |
Going to play semi-devil's advocate here:
A few questions... When you were driving the car; did you have any type of gas smell? I know on the 97 model year; there was an issue with the fuel pumps- that was specific to the 97 model year only...ask me how I know. If you had that; then it was a sure sign of the Fuel Pump failing. If you haven't changed out the alternator; then that may be the next thing on your list. I would suggest getting the battery checked/tested at your local auto store... I have had new batteries die within 6 months or less of purchase.
Bryan 94SL2 HCE, "Pearl" 99 SL 94SL2 260K Miles 1/15 97SW2 266K Miles 2/15 Always 94SC1 340,501 Miles Org. Engine/Auto Trans 2/97-10/08 Gone 3/12 92SL1 05VUE 91SC |
#6 | |
![]() Quote:
they're not too hard to replace if you jack the car up sufficiently to get under it comfortably (and support it well with jack stands of course!) and they can be had at the jy for cheap enough if you're so inclined as to go pull the part yourself. sometimes you find a really new one on one of the cars, it's worth peeking at them all for that reason. honestly though as long as you don't have some massive electrical problem or a bad battery that's constantly pulling too much current from the alternator, they don't fail that often even when it is a random used one. i've thrown on well-used spares that came with donor engines the two times alternators on my cars went and haven't seen an issue since on either car.
rings-1996 sl2 ~215k mi phoebe-1995 sl1 ~250k mi janus-2000 sohc2 ~190k mi tethys-1994 sw2 ~302k mi rip mimas-wrecked 1996 sw1-trailer pandora-1999 sc2 dione-1998 sw2 penny [iapetus]-1997 sw2 |
Bookmarks |
Car died while driving | Hjoken | S-Series Tech | 5 | 02-05-2022 09:10 PM |
1999 SL2 Just died when Driving | lionfish37 | S-Series General | 16 | 12-24-2016 04:29 AM |
'05 ION 1 Died While Driving | DrHicks | Ion Tech | 17 | 12-20-2014 03:45 PM |
95 SL1 just died while driving. | Morkstall | S-Series Tech | 7 | 03-07-2014 10:37 PM |
97 sl died while driving | tigereyes91342 | S-Series General | 16 | 01-20-2011 04:32 PM |
