Old 05-11-2022, 05:24 PM   #1
onlinebiker
onlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to all
Default This must be a supplier thing
Our 99 SC2 (A) blew out a brake line - in the usual spot - under the driver' s door. It was the passenger's side line.
Odd thing - it was very rusty and brittle, with hard scale rust - but - the driver' s side was 90% clean with only mild surface rust.
Normally I would just replace both - but this time?
I decided to just do one.
All I can figure is that the two lines had different metalurgy - and may have come from different suppliers.
Anyone else ever run into this?
Currently owned
93 SC2 M(anual)
96 SC2 M
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 05-11-2022, 07:00 PM   #2
bumpdraft
bumpdraft's Avatar
1998 SW2
Default Re: This must be a supplier thing
It might be that rust begets rust.
More better rust paranoia** needed in late August, when everything is dry and life is easy POR15
**for ex. l am adding tie wire safety anchors to my exhaust system for when a support or flange gives out. I don’t want to drop the midpipe into a pothole or transverse crack.
Old 05-14-2022, 12:06 AM   #3
TomM96
During early 80s I replaced brakelines on a '73 Chevy pickup.
By that point I had discovered that the aftermarket lines from NAPA
began to rust after a year or two, while the ones from GM lasted
at least 5-10 years.
Thickness of the galvanizing is a lot of it. But odd to see one of the two
Sat lines go without the other.
Old 05-14-2022, 09:24 AM   #4
ultravioletnk
ultravioletnk will become famous soon enough
ultravioletnk's Avatar
2000 SC2
it might've just been a manufacturing defect, such things do happen... and i'm lucky here in co but i've never had a brake line rust out on any of my vehicles.
rings-1996 sl2 ~215k mi
phoebe-1995 sl1 ~250k mi
janus-2000 sohc2 ~190k mi
tethys-1994 sw2 ~302k mi
rip mimas-wrecked 1996 sw1-trailer
pandora-1999 sc2
dione-1998 sw2
penny [iapetus]-1997 sw2
ultravioletnk is offline   Reply With Quote
Old 05-16-2022, 10:46 AM   #5
TomM96
On both my '97 & 2000 both lines were pretty similar. However, I Do
now recall that one (likely the inboard one) on my 2000 Did have a bit
more degradation, which I scraped off prior painting it.
I only remember this because it was just last November that I painted them.
I recall wondering, why is this??
Battery Supplier Issue BradT Vue Green Line 0 02-28-2008 07:30 PM
Supplier Discount liquidslap Aura General 1 12-21-2006 01:15 PM
GM Supplier Discount lg68jcu Vue General 18 01-26-2006 05:58 PM
GM Supplier Discount 04SilverVue Vue General 22 09-21-2004 01:23 PM
GM Supplier Discount for VUE + More VUE WATCHER Vue General 11 01-31-2002 01:33 AM
