Old 04-21-2022, 08:09 PM   #1
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
Default Coil Spring Isolators...
How come you have them when you buy all-in-one struts but they're not available separately? Are these things actually available anywhere, or is it off to the pick and pull to get one of these?
Goggles Pisano is offline   Reply With Quote
Old 05-12-2022, 03:22 PM   #2
TomM96
TomM96 has a spectacular aura aboutTomM96 has a spectacular aura about
Default Re: Coil Spring Isolators...
I try Summit racing, Rock Auto, Parts Geek online...
then also ask at FLAPS, NAPA & Carquest/Advanced, or an independent shop.
Old 05-14-2022, 12:29 AM   #3
Goggles Pisano
1999 SL1
I had hedged my bets. I went to a Pick 'N' Pull and grabbed the isolators on the front, as well as a pair of rear strut mounts that had the rubber. At the same time, I ordered two different sets of Energy Suspension coil spring isolators.
Turns out that the rears were unneccessary as the isolators are built into the rear strut mounts. The front isolators could've been made to work somehow with some trimming, but the scavenged original isolators worked a lot better. The SL is a lot less noisy now on low speed turns.
Old 05-16-2022, 10:17 AM   #4
TomM96
Are "isolators" = "strut mounts" ??
Old 05-17-2022, 11:55 PM   #5
Goggles Pisano
1999 SL1
Not on the fronts. These sit between the strut mount and the spring. You'd find them on the all-in-one Quickstruts but they are not sold separately.
coil spring Cavell Vue General 0 03-08-2017 05:00 PM
broken coil spring scotttomlin S-Series Tech 14 07-17-2014 06:20 PM
coil spring for a 2002 SL2 ky saturn S-Series Tech 5 10-19-2010 03:51 PM
coil spring re use??? bendover817 S-Series General 2 08-17-2010 10:41 PM
coil spring culdri L-Series Tech 2 04-18-2009 04:29 PM
