![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2015
Our 99 SC2 (A) blew out a brake line - in the usual spot - under the driver' s door. It was the passenger's side line.
Odd thing - it was very rusty and brittle, with hard scale rust - but - the driver' s side was 90% clean with only mild surface rust. Normally I would just replace both - but this time? I decided to just do one. All I can figure is that the two lines had different metalurgy - and may have come from different suppliers. Anyone else ever run into this?
Currently owned 93 SC2 M(anual) 96 SC2 M 98 SL2 A(uto) 99 SC2 A 01 SC2 A 01 SC2 M 02 SC2 M 02 SL2 A 02 SL2 M parts 2 94 SC2 parted out 2 96 SC2 98 SC2 - rusty frame minus engine. 98 SL2 |
It might be that rust begets rust.
More better rust paranoia** needed in late August, when everything is dry and life is easy ![]() **for ex. l am adding tie wire safety anchors to my exhaust system for when a support or flange gives out. I don’t want to drop the midpipe into a pothole or transverse crack. Last edited by bumpdraft; 05-11-2022 at 07:10 PM. |
![]() ![]() Join Date: May 2004
During early 80s I replaced brakelines on a '73 Chevy pickup.
By that point I had discovered that the aftermarket lines from NAPA began to rust after a year or two, while the ones from GM lasted at least 5-10 years. Thickness of the galvanizing is a lot of it. But odd to see one of the two Sat lines go without the other. |
it might've just been a manufacturing defect, such things do happen... and i'm lucky here in co but i've never had a brake line rust out on any of my vehicles.
rings-1996 sl2 ~215k mi phoebe-1995 sl1 ~250k mi janus-2000 sohc2 ~190k mi tethys-1994 sw2 ~302k mi rip mimas-wrecked 1996 sw1-trailer pandora-1999 sc2 dione-1998 sw2 penny [iapetus]-1997 sw2 |
#5 |
On both my '97 & 2000 both lines were pretty similar. However, I Do
now recall that one (likely the inboard one) on my 2000 Did have a bit more degradation, which I scraped off prior painting it. I only remember this because it was just last November that I painted them. I recall wondering, why is this?? |
Battery Supplier Issue | BradT | Vue Green Line | 0 | 02-28-2008 07:30 PM |
Supplier Discount | liquidslap | Aura General | 1 | 12-21-2006 01:15 PM |
GM Supplier Discount | lg68jcu | Vue General | 18 | 01-26-2006 05:58 PM |
GM Supplier Discount | 04SilverVue | Vue General | 22 | 09-21-2004 01:23 PM |
GM Supplier Discount for VUE + More | VUE WATCHER | Vue General | 11 | 01-31-2002 01:33 AM |
