Old 11-18-2021, 01:04 AM   #1
TomM96
Default About bearing kit 'on car' replacement
Request clarification-
The idea/narrative is by leaving the strut fasteners untouched, that the
alignment will not change ?
One still needs remove control arm (LCA) to spindle ball joint, and maybe tie rod end ball joint, in order to get access to remove drive axle from spindle ?
{and access for press tool to spindle-bearing assy}
tia...
Old 11-18-2021, 01:31 AM   #2
Default Re: About bearing kit 'on car' replacement
You can avoid needing to re-align by just marking the strut relative to knuckle. No super precision is needed, just a Sharpie or scribe mark can do it.
Old 11-18-2021, 08:53 AM   #3
TomM96
Thank you, Bill.
That adds a degree of freedom !
front hub and bearing replacement? hedgehog S-Series General 2 02-03-2013 03:48 AM
06 Vue Wheel Bearing Hub Replacement dleclerc Vue Tech 3 01-03-2013 11:58 PM
Hanger bearing replacement Oliverjackson Vue General 4 03-23-2011 05:20 PM
Replacement of bearing hub without ABS stlmusic Vue General 7 07-29-2010 10:39 AM
Rear bearing/hub replacement conefree S-Series General 18 01-11-2006 03:13 PM
