Old 09-21-2020, 10:11 AM   #1
TeeDub24
TeeDub24 is on a distinguished road
Default 2004 Saturn Ion clutch diagnosis... Help Please...
About a month ago my clutch wouldnít engage until the pedal was nearly compressed to the floor. Itís to the point now that it wonít even engage the clutch to allow the transmission to shift. There is plenty of fluid in the reservoir, so I pulled the bleeder hose just to make sure fluid is making it to the slave cylinder... and nothing. Canít get a drop out of it and now my pedal is obviously limp. Do I need to try and vacuum pump the system? Or did I finally lose my master or slave cylinder? I had a transmission guy tell me itís for sure the slave cylinder and itíd be $1300 to fix... ouch. I really donít want to drop that kind of money, the car has 206k miles on it, so plenty of life left. Any help and second opinions on what my options are would be greatly appreciated!!! Thanks yíall.
TeeDub24 is offline   Reply With Quote
Old 09-23-2020, 05:06 PM   #2
Bill Murray
Bill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the rough
2007 ION-2 Quad Coupe
1997 SC1
Default Re: 2004 Saturn Ion clutch diagnosis... Help Please...
Based on your full reservoir, sounds like there's no external leakage.
So either the fluid is bypassing in the master cylinder (not creating pressure) or bypassing in the slave cylinder and not pushing on the clutch fingers.
Here's some YouTube info:
https://www.youtube.com/watch?v=WJQO82P5264
The 1300 bucks is mostly labor since the trans has to come out. The slave cylinder is concentric on the transmission input shaft.
And typically if you do that, replace the clutch disk, pressure plate, and slave cylinder. Not sure how much your car is worth but that's why a lot of them go to the junkyard.
Old 09-24-2020, 01:19 PM   #3
TeeDub24
Thanks Bill. Iíll refer to that YouTube video and see what I can find out.
Tags
clutch problem, help please, ion
Clutch Hydraulics Diagnosis BarnOwl How-To Library 24 03-25-2017 09:16 PM
2004 saturn vue clutch problem old65stang Vue Tech 0 05-06-2014 09:57 PM
02 SC1 manual trans or clutch is out, Need help with diagnosis downshift93 S-Series General 10 03-19-2011 07:36 AM
Confirming diagnosis: bad clutch? HappyCJ S-Series Tech 12 03-24-2010 12:28 AM
Diagnosis help 98 sl2 clutch? transmission? hatrik8 S-Series Tech 7 05-11-2007 05:15 PM
