Old 09-01-2012, 12:49 PM   #1
tmoncrief
tmoncrief is on a distinguished road
Default question about radiator stop leak helping a leak from the plastic end caps
Hi, folks, I have a 95 SL1 and for the last week it has been losing coolant. I was not able to tell where the leak was exactly until I put it under pressure today. Rented one of those pressure testers and saw that there is a leak on the drivers' side radiator end cap (the plastic one) between the first and second ribs, down from the top. Has anyone had any luck with the commercially available stop leak for radiators being effective on this sort of leak? Or would a new radiator be better and safer?
tmoncrief is offline   Reply With Quote
Old 09-01-2012, 01:22 PM   #2
tmoncrief
Default Re: question about radiator stop leak helping a leak from the plastic end caps
Also, I need to mention that it is a manual and not an automatic, that may make a difference as I understand the automatic has an additional fitting.
Old 09-01-2012, 01:43 PM   #3
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Get a new radiator, stopleak is unlikely to help much if at all. A heads up: you'll probably only find auto trans radiators when you shop for one. They work fine on manual trans cars.
SaturnSeries.net owner
Old 09-01-2012, 06:32 PM   #4
HandsOn
HandsOn is on a distinguished road
1997
I've used stop leaks with good results several times, but if I had an aluminum/plastic radiator starting to split at a seam, I'd follow PurdueGuy's advice and just get a new one.
Not sure about our cars, but in general, new modern car radiators are not that expensive and not that hard to fix.
If I was on a trip and just wanted to get down the road in a hurry. I'd give Solv-Tec K-Seal a try for a temporary fix. It's effective in the right cases and relatively inexpensive.
If it didn't work right away though, I'd be looking for the nearest radiator supplier before it got any worse.
Paul
HandsOn is offline   Reply With Quote
Old 09-01-2012, 07:07 PM   #5
Stop leak will not hold on a tank and it will block the heater core. If you use stop leak don't come here to whine and moan this winter about no heat.
Buy a Delphi or Silla radiator and be done with it.
Old 09-04-2012, 08:06 AM   #6
simkid5614
simkid5614 is on a distinguished road
simkid5614's Avatar
End of thread.
Replace the Parts.
Never use Stopleak.
Yay for mass agreement
(sorry, just get tired of hearing stopleak this and stopleak that.)
2002 SL2 115k "Whisper" No leaks!! :) 115 and going strong..
simkid5614 is offline   Reply With Quote
Old 09-04-2012, 02:51 PM   #7
bountyhunter
bountyhunter will become famous soon enoughbountyhunter will become famous soon enough
1992 SL2
Did not work on my SL2.
bountyhunter is offline   Reply With Quote
lw300 v6 radiator stop leak - how lw300v6 L-Series Tech 6 05-25-2012 12:53 AM
94 SL2 Radiator Leak UPDATE Question plumstheword S-Series Tech 8 08-08-2007 08:07 AM
Radiator leak in plastic housing under the upper rad hose. technopop S-Series Tech 9 06-29-2007 05:51 AM
leak in plastic area under upper radiator hose intake. technopop L-Series Tech 0 06-28-2007 03:00 PM
evaporator core leak -- opinions on 'stop leak' products? brenspin S-Series Tech 12 01-31-2006 12:29 AM
