#1 |
![]() Join Date: Jun 2009
Hey guys, new to the forum and relatively new to Saturn ownership. Bought My '95 SL as a cheap 'beater' after selling my more valuable car to pay down bills
![]() My fuel pump died on Wednesday and I just got around to changing it today. Took 4 hours, about an hour of which was to figure out how to do it without jacking the car way up (yes it can be done ![]() So I get it together, pump runs fine, engine starts right up but I notice the fuel gauge is now stuck on 'F'. What did I do wrong? Is it possible to put the sender in backwards so that the float impinges the tank? Or do I just need to re-install the pump ass'y being sure that the float is 'dangling' free? Any help appreciated! Jimbo |
#2 |
Back at the electrical connector you measure the resistance of the sensor in the tank. measure between B and C, blk/wht and purple. Full tank is 18 ohms, 3/4 is 68 ohms, 1/2 is 113 ohms, 1/4 is 163 ohms, 1/8 is 195 ohms, and fumes is 677 ohms. You could insert a 120 ohm resistor in the connector towards the gauge and then the gauge should read just below 1/2. This would tell you the gauge was working. The resistance reading of the sensor will tell you if the float is hung up. You might have pinched a wire also.
Did you change just the pump or the entire unit? Was it new or a J/Y special? |
#3 |
The pump was new, so I had to assemble it into the plastic 'cage'. But everything seemed to only go together 'one way', and I was very careful with alignment, wire routing etc. The sensor wires were not disturbed, AFAIK.
Thanks for the checking info, I'll use it tomorrow before I dive in again. Jimbo |
#4 |
Thats the plan, find out where its broke. there are some words in the FSM about installation so as to not screw up the float. i will dig them out in the AM as thy might be critical. The resistance will tell you what is going on though.
#5 | |
![]() Quote:
I've had enough car work for one weekend; decided to put it off till next weekend. Now I just have to keep from running out of gas this week ![]() Jimbo |
#6 |
I can relate to that....
Bookmarks |
2002 Vue,fuel pump changed-still wont always start! cannot risk driving it | montrealgrrl | Vue General | 9 | 08-25-2009 02:15 PM |
Fuel gauge stuck | TobyG | Vue General | 6 | 02-17-2009 03:30 PM |
92 SC2 Fuel gauge - never full, never empty | Wizard Prang | S-Series Tech | 5 | 04-03-2008 09:55 AM |
2000 LS1 with wacky fuel gauge? pump? What? | SloMo2000 | L-Series Tech | 1 | 12-02-2007 10:45 AM |
Fuel gauge?? Pump?? | msgrape | Vue Tech | 6 | 06-30-2007 05:42 PM |
