Old 07-27-2008, 07:34 AM   #1
saturn94v
saturn94v is on a distinguished road
saturn94v's Avatar
1994 SC1
Dizzy FUEL PUMP or FUEL SENDING UNIT?..
So...I have no fuel pressure. (this has been on going) my question is....
Can this be only the fuel pump, or could it possibly just be the sending unit?
Does my 94 sc-1, 1.9L SOHC have a sending unit? Can these items be replaced seperately? The cost of said fuel pump is forcing me to look into other options.
94 SC1 1.9L SOHC
GM Blue Green
278,429 miles
32+/- AVG/MPG
saturn94v is offline   Reply With Quote
Old 07-27-2008, 08:58 AM   #2
TwinRevver
TwinRevver is on a distinguished road
Default Re: FUEL PUMP or FUEL SENDING UNIT?..
did u check the fuse relay and the connector in the trunk dvr side? try banging on the bottom, of gas tank w/ ur hand to get it loose
now with problems and getting a newer car but not a saturn :(
My 95 SL2 white top of the line car Priceless..
TwinRevver is offline   Reply With Quote
Old 07-27-2008, 09:47 AM   #3
Squareback
Squareback's Avatar
2005 ION-2 Sedan
The sending unit has nothing to do with fuel pressure. It simply tells the gauge how much gas is in the tank. If the sending unit was bad, your gauge would read empty all the time, or possibly full all the time. You need a fuel pump.
Certified Saturn Technician
Old 07-27-2008, 10:09 AM   #4
wolfgang2204
wolfgang2204 is on a distinguished road
Ouch! Apparently, somewhere on line you can get just the pump for just over a hundred dollar bill. Do a search for my other thread about fuel pumps as someone replied to it with some info.
wolfgang2204 is offline   Reply With Quote
Old 07-27-2008, 10:12 AM   #5
Actually, creative shopping will get just the pump for a bit under the 100.00 price. You want to replace the in tank filters also. A new assembly is quite a chunk of change. RockAuto has the parts and of the non eBay sellers they also are the low price.
Old 07-27-2008, 10:34 AM   #6
saturn94v
saturn94v's Avatar
1994 SC1
Really? You mean that I can just replace the pump motor? So how do i replace just the pump with out destroying the whole assembly? I don't see how to pull it apart to access the pump motor with out "breaking in."
I would definitely by new verses used, if I could. Thanks for all your help.
94 SC1 1.9L SOHC
GM Blue Green
278,429 miles
32+/- AVG/MPG
Old 07-27-2008, 10:40 AM   #7
I have an assembly for a 98 here that I am planning on rebuilding but have not investigated just how you get the pump out of it. Some one on here has done it and they will be along eventually to explain how its done. It looks doable though.
You sure do not want to buy the entire unit new. Or install one out of a dead car with an old pump in it.
Fuel Pump and sending unit L-300 01SatL300 L-Series General 7 07-11-2015 01:29 PM
How do you remove fuel pump/sending unit? ringman S-Series Tech 9 02-27-2007 02:49 AM
Fuel Sending Unit jswingchun S-Series General 1 08-21-2006 10:27 AM
fuel sending unit ammotrooper General Saturn Discussion 10 06-03-2003 07:28 AM
Fuel Sending unit? SLeepr Miscellaneous Tech 2 11-07-2002 10:47 PM
