#1 |
![]() Join Date: Jan 2005
I'm on my third power steering pump shaft seal on my 96 SL2 with 130,000 miles. So that's about 44,000 mi per seal. The first bad seal was detected & replaced by the dealer (under warranty), the other two were replaced by me.
Just wondering if you guys thought this was normal. Thanks. |
#2 |
I have just over 250,000 miles on my orginal in my 1993 SW
#3 |
250,000? ----- wow. I guess it's just me then.
I thought maybe the shaft was bend or something causing it to wear prematurely but it spins pretty straight. |
#4 |
My guess is that there is a faulty part on the pump itself causing the seals to go bad.
#5 |
Luke's at over 400,000; ask him. A bend or imperfection in the shaft sufficient to blow the seal over tens of thousands of miles won't necessarily be visible as a deviation in the spin of the pulley.
Have you had to remove the pump to change out this seal? How much has it cost each time, compared to a new pump? Based on that proportion, if you plan on keeping this car for several hundred thousand miles, a new pump might be in order. 'Course, if it's relatively cheap, you might just want to consider it another periodic maintenance item, like coolant or tranny fluid. |
#6 |
I pull the pump out myself and replace the seal for about $10.00 per seal plus the cost of new PS fluid. I borrow a pulley-puller from a friend.
I thought about getting a new pump but a the cost scares my wallet--$300.00+ (most in this forum recommend oem from dealer). thanks for all the input. |
#7 |
Try the junkyard. Just search around and find one that doesnt look like its been leaking. Heck, you could pull a good one and replace the seal while it out and you should be good to go.
Bookmarks |
Replacing Power Steering Pump Seal | okubricko | L-Series Tech | 0 | 07-27-2009 10:30 AM |
Power Steering Pump -- Shaft seal replacement?? | hholbein | S-Series Tech | 30 | 03-22-2009 10:51 AM |
Power steering pump seal replacement | unr.grad | S-Series Tech | 2 | 10-13-2008 04:01 PM |
How do I Replace Power Steering Pump Seal? | Old Crow | S-Series Tech | 0 | 10-06-2006 06:13 PM |
Power Steering Pump Seal | DaveL167 | S-Series Tech | 8 | 12-09-2003 01:26 AM |
