Old 12-08-2003, 08:32 PM   #1
DaveL167
DaveL167 is on a distinguished road
Default Power Steering Pump Seal
'97 Saturn SL1
Went to get 66K mi oil change at Saturn service & found out there was a power steering pump seal leak. Cost to fix was $207. Is this accurate?
Thanks,
Dave
DaveL167 is offline
Old 12-08-2003, 09:22 PM   #2
DaveL167
Default
'97 SL1
Oh yes, another question...is this something I can wait to repair or does it need to be done ASAP? I told them no to fix it and that I would get back to them.
Thanks,
Dave
DaveL167 is offline
Old 12-08-2003, 09:27 PM   #3
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
Default
How much PS fluid do you have to replace. If you only have to add once a month or so, I would wait.
Your Honor Student is merely a pawn in my Min Pin's diabolical world domination plot.
Obey the Min Pin
lostwages_ls2 is offline
Old 12-08-2003, 11:32 PM   #4
geartooth94
geartooth94's Avatar
Default
for reference, on my '94 SL2 the PS pump was diagnosed as being bad about a year ago by Saturn. It was going to cost $503 to fix because of a new bracket--you can guess what I said.
The symptoms were very hard to turn steering wheel only in the tightest of maneuvers, e.g. parallel parking.
Today it is still doing its thing and the symptoms have not gotten any better or worse for that matter. My PS fluid level has remained unchanged.
good luck.
geartooth94 is offline
Old 12-08-2003, 11:41 PM   #5
MaxSL2
MaxSL2 is on a distinguished road
MaxSL2's Avatar
2003 VUE 2.2L
Default
It probably does leak a little, that seems to be common. You will notice that the white PS fluid container gets black crud flung onto it. Unless it looks like there is fluid leaking onto the alternator, or you have to top the PS fluid off with any regularity, it should be OK.
My '96 leaked also but it was only enough to have the level go down maybe 2 Oz. every few months, no big deal really.
That is prob. about right for one from Saturn installed. I'm assuming they just put a rebuilt pump on, as the cost with labor to R&R just that seal is probably almost as much as just replacing a pump.
If you wanted to do this yourself, a rebuilt pump from an auto parts place is probably $80 max after exchange. Just the seal could be had for mabye $5, but is probably a pain to change.
MaxSL2 is offline
Old 12-09-2003, 12:01 AM   #6
DaveL167
Default
'97 SL1
OK thanks for the info. Unfortunately I never asked the the service guy if it's something that needs to be fixed right away altho I have a feeling he would say yes even if it didnt. How can I check this myself?
Thanks,
Dave
DaveL167 is offline
Old 12-09-2003, 12:04 AM   #7
Dr. Bob
Dr. Bob is on a distinguished road
Default
I had a power steering pump leak and because the steering was stiff, the techs replaced the pump.
I think, but maybe one of the techs can confirm, that if the pump is operating ok, the seal can be replaced at significantly less money.
Dr. Bob is offline
Old 12-09-2003, 12:43 AM   #8
DaveL167
Default NEW WATERPUMP
'97 SL1
actually, I just had a new water pump assembly installed about 4 mo's ago by Saturn since it was leaking. Isnt the power steering pump seal connected? I'm asking to see if it would be under warranty.
Thanks,
Dave
DaveL167 is offline
Old 12-09-2003, 01:26 AM   #9
Default
PS pump seal no no way affected by replacing the water pump. check for oil that is being sprayed from the the PS pump pulley onto the firewall and underside of the hood. If there is wet oil there then it would be a good idea to replace the seal. Bad enough leak will dump oil onto the alt and eventually fry it. flate rate labour for the seal is 2.0 hours plus parts. The seal here ia about 10-15 dollars CDN.
ssicarman is offline
Replacing Power Steering Pump Seal okubricko L-Series Tech 0 07-27-2009 10:30 AM
Power Steering Pump -- Shaft seal replacement?? hholbein S-Series Tech 30 03-22-2009 10:51 AM
Power steering pump seal replacement unr.grad S-Series Tech 2 10-13-2008 04:01 PM
How do I Replace Power Steering Pump Seal? Old Crow S-Series Tech 0 10-06-2006 06:13 PM
power steering pump seal kmix99 S-Series General 6 02-08-2005 12:05 PM
