#1 |
![]() Join Date: Dec 2014
Hi there,
Well, this is my first post (long time reader). So, my 96 Saturn SL2 didn't like going fast around curves and the front right suspension needs to be replaced (basically everything). Of course, I blame it all on the curb: ![]() In any event, the mounting bracket attached to the front right strut and inner tie rod is cracked, and will need to be replaced. Is my best best a junkyard? I can't even figure out what this part is called, to see if it's even available at a auto parts shop. Can someone help me verify exactly what this part is called and, if possible, a part number? I can't find it on Gmpartsdirect.com, but I may not be searching for the correct term. Any help would be much appreciated... |
#2 |
UPDATE: I have also attached some photos of the mounting bracket I'm referring to.
#3 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2016
That is a steering knuckle. Driveshaft looks bad too. You may want to replace the control arm as well. It is either bent, or since you have to do an alignment anyway this is a great time to replace them.
I'd get the knuckle at the junkyard, other parts I'd buy new.
Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018 |
#4 | |
![]() Quote:
#5 |
Wow, it looks like I can't buy a steering knuckle anywhere new, I guess I'll have to use a junkyard.
#6 |
![]() ![]() Join Date: May 2004
> " I can't buy a steering knuckle anywhere new "
Yah! Car mfgrs generally provide replacements for consumable aspects of their retail creations. Steering knuckles are 'FORGED', one of the strongest methods of fabricating metallic articles. They are never expected to fail. Traditionally, steering tie rods were made of soft material, but these are now stiff, which is tough on the knuckles. A junkyard replacement should be fine. |
#7 |
![]() ![]() Join Date: Mar 2001
You need to really take a good look at the subframe before you put a lot of work into this. The subframe mount to the lower control arms can be bent and if they are it will require a replacement sub frame as well.
Tie rods on the impact side make sense as well. The other side is your call, I think you could argue either way. FYI... my inner tie rods are factory original. I'm guessing a new wheel and tire is in the plan as well. Highmile '95 SL1 666k and counting |
#8 |
Wow, that is a very good point. Attached are the photos from the damaged side. I'm guessing this will cause major alignment issues if I don't replace the subframe?
#9 |
ROFL...
NateDawg, you did real nice job! Yes, a new subframe will be required. The open slit would accept water; the spacial derangement would affect at least the alignment. It's an opportune time to upgrade the cradle- >shop with care for low rust >coat with POR or favored paint |
#10 | |
![]() Quote:
Bookmarks |
alternator mounting bracket... | edzdallas | S-Series General | 4 | 08-11-2006 10:26 PM |
Mounting front license plate w/o bracket? | BODKAx3BEPb | S-Series General | 7 | 06-06-2006 09:04 PM |
WTB CD Changer mounting bracket | SC2Boy | Classifieds | 3 | 02-23-2006 01:04 AM |
Mirror mounting bracket | 63pontiacgp | L-Series General | 4 | 02-19-2006 12:26 AM |
WTB: Mounting Bracket for SPS Hotshot Intake | goldenSL1 | Classifieds | 1 | 09-26-2002 11:24 PM |
