#1 |
![]() Join Date: Jan 2005
2004 VUE 3.5L
I have been having issues with the remote key fob on my 2004 Saturn vue. The buttons would not always work and I had to press many times or press real hard until lately it rarely worked. Also the buttons would sometimes stick in the pressed down position. So I took it apart. The battery checked at 3 volts and there was no damage to the battery contacts. I noticed that black rubber had smudged up the circuit board where the buttons make contact. I cleaned it off very gently with a Q tip and a tiny amount of alcohol until all of the black rubber was removed. I also cleaned off the bottom of the buttons with same. Then I cleaned the top and side edges of the buttons with alcohol and cloth to fix the sticky button issue. After a good cleaning of the case at the snap joint, I reassembled. It now works like new. Easy.
#2 |
![]() ![]() Join Date: Jun 2010
Excellent tip - thank you.
#3 |
![]() Join Date: May 2013
X2 good info
#4 |
![]() Join Date: Sep 2013
I will have to clean it with some alcohol. I had the sticking issue and took it apart one day when I had time to burn, I used a screwdriver to scrape all the sludge off the buttons but it still sticks.
Bookmarks |
Tags |
key fob, keyfob, keyless, remote |
OMG A FIX for the KEYFOB | Askspot | Aura General | 0 | 09-29-2011 04:46 PM |
KeyFob Reliability | 08blkastra | Astra General | 3 | 11-14-2008 06:24 PM |
08 Vue KeyFob / remote / keyless programming? | loly75ddl | Vue General | 1 | 04-22-2008 08:11 PM |
03 Ion remote keyfob programming ? | Barrycraig70 | Ion Tech | 15 | 06-02-2006 03:32 AM |
RKE Keyfob | Diggs | General Saturn Discussion | 8 | 10-10-2000 01:57 PM |
