#1 |
![]() Join Date: Jan 2005
2004 VUE 3.5L
My 2004 Vue AWD 3.5 V6 A/C will only work in fan speed 1 & 2. When I place the fan switch to 3 or 4 the A/C light goes out and the A/C shut offs but the fan works at higher speed like normal. Recently I have also had an issue with the A/C button that when you pressed it the light would not go on or would go on then quickly go off or only work in fan speed 3 or 4. Its messed up. Is it the hvac module (where the switches are) or some other Hvac control device that I should look at? Thanks
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2008
![]() Quote:
The card used to cost around $50 US and is a DIY swap-out. Please repost if you'd like assistance tracking a replacement down and if you'd like procedures to change.
I visit forum monthly, if at all. Feel free to send private messages if you think I can help. Don't use visitor message as I never check those. |
#3 |
2004 VUE 3.5L
Thank you. Yes I would appreciate information on purchasing and replacing the blower motor resistor circuit board. Is this a GM dealer part only or available aftermarket?
#4 | |
![]() Quote:
Question is - can you order direct from these folks at US prices or is there some sort of customs fees. IDK. See attached extract to locate and access the blower motor - I believe the resistor card has a detachable connector and is held in place with two screws. I'll email complete instructions if you PM an address.
#5 |
![]() ![]() ![]() ![]() Join Date: May 2008
2006 VUE Red Line
IIRC, if we Canadian's order from RA I beilive the final price they provide at checkout includes the shipping and all duties/taxes. I don't recall having to pay any extra duties on my last RA order.
.................................................. Saturn Vue: The 250 HP tupperware |
#6 |
2004 VUE 3.5L
I replaced the blower resistor and its now working fine. I paid $37 at RockAuto plus shipping for an orginal ACDelco part. The local dealer wanted $85 for the same part. I bought of bunch of other stuff on the same order so the shipping cost was relatively small per part. Its located under/behind the access panel (2 screws) under the glove box/dash. Its a pain to replace since the 2 8mm bolts for the resistor are right up against the firewall and access is tight. One of the bolts is directly above and tight against a bump in the rubber dash mat but its somewhat fexible if you push hard. You need a small closed end wrench, ratcheting would be sweet. Just need to be patient and a bit of a contortionist. I removed the part before removing the harness since the harness needed a little bit of prying.
#7 |
Thanks for posting the update!
2009 Aura XE 2.4-----SOLD 2004 Vue 3.5 AWD 1999 SL2 Auto 1998 SL2 5-Speed------SOLD 1996 SL1 5-Speed |
#8 |
![]() Join Date: Jan 2012
I have a simular problem with my 2001 L300. All fan speeds work fine but the AC and/or recirculate only work as long as I hold the button in. As soon as I release the button the light goes off and AC stops working. Could this be the blower motor resistor also or will it be the control module itself. Again as long as I hold in the buttons everything is working fine. And all four fan speeds are working.
#9 | |
![]() Quote:
Which air delivery option is selected when you must hold recirc button down for light to stay on? Do you have 2.2 or 3.0? There appear to be drawing differences.
#10 |
2.2 and any fan speed selected. Not sure about resurculate on this L300. I still have a SL1 but both the AC and the recirculate buttons are the kind that stay depressed when you push them. The ones on the L300 actually return to the original position after releasing even when working properly.
#11 | |
![]() Quote:
The HVAC schematics don't show inner workings of the HVAC controller. It appears since AC and RECIRC functions operate when the switches are pressed and held - the external voltage and ground paths are OK. Is it possible the RECIRC circuit won't stay latched because you're trying with air delivery set to an incompatible mode. For example - RECIRC should not activate when mode switch is set to either defrost or heater/defrost. I don't see any connection between the AC switch circuit and the blower motor resistor card. Power for the AC switch is provided by the blower motor speed switch but not when switch is set to OFF. If the AC light will not stay ON - and blower switch is set to any position other than OFF - you could have a HVAC controller problem or perhaps a refrigerant pressure problem. The normal path (my best guess) is if AC circuit in HVAC controller latches a voltage is sent to the BCM. The BCM generally monitors evaporator temperature and if freeze-up is not likely - the PCM sends AC request signal to the PCM using serial data circuit. The PCM monitors AC pressure (in-line sensor) and if sufficient static pressure is present the PCM should enable AC relay to run the compressor. I don't see a feedback circuit to keep the HVAC controller from turning the AC light ON if static pressure is LOW but I think I would check the pressure before replacing the HVAC controller (unless it can be returned if not the problem).
#12 |
far2grumpy thanks for the help. Changed the HVAC today and everything works again. The resistor was not the problem. Apparently the two buttons controling the AC and Recirculate went bad and would not stay engaged. Not sure how those buttons work internally but I will be taking them apart to learn. Was able to get the new HVAC from a junk yard so no big expense this time, but in the future may be able to just replace the buttons on the HVAC circut board. Not sure. Thanks again.
#13 | |
![]() Quote:
#14 |
![]() Join Date: Dec 2012
1994 SL1
2003 VUE 2.4L
This problem appeared today on my '03 VUE. Do you still have the directions to gain access to the board to replace it?
Mike |
#15 |
Mike ... see the attached files - the blower motor is behind the glove box - get in touch if you think of anything else that'd help.
#16 |
1994 SL1
2003 VUE 2.4L
Thank you, I will have to order the part first, I saw the link above and the part to order.
Mike |
#17 |
1994 SL1
2003 VUE 2.4L
I purchased the AC Delco blower resistor as described above, Replaced it today and the AC stays on now on all four fan settings. Thank you for your help!
![]() Mike |
#18 |
![]() Join Date: Jun 2016
I had the same problem with my 2006 vue. A/C only worked on speeds 1&2. I found the blower motor resistor on carparts.com for $20.00. The part came in today and took 20 minutes to install start to finish and now it works on all 4 speeds. I removed the blower motor shield and the glove box to get better access although I think I could have left it in and just remove the cover. The part is right against the firewall right where the carpet ends. One screw was easy to get at the other I had to push the carpet down a little bit, otherwise it was a very easy job
#19 |
![]() Join Date: Apr 2019
Sure is hard to get to, or that one nut up against the wall. Think I got it in some what. AC light on for all 4 settings . Seems to be blowing cold will have to see when it gets hot out again. Thanks for the help.
#20 | |
![]() Join Date: Nov 2008
7/27/19
My 2005 Saturn Vue had the same problem as OP. Grumpy was right. Blower Motor Resistor I bought from Amazon for $ 22. Install is tricky as per, but, works fine. Thanks for the help folks! Quote:
2005 VUE AWD 3.5L V6 |
Bookmarks |
A/C only works on low fan speed | VTVUE | Vue General | 25 | 08-15-2019 07:17 PM |
Removing the Speed Limiter: Disconnecting the Input and Output Speed Sensors | AlexofNazareth | S-Series Mods | 35 | 11-19-2010 07:21 PM |
Radiator Fan Only Works on High Speed | JuniorTT | Ion General | 7 | 06-06-2010 11:03 AM |
More Six-Speed Automatics Coming as GM Announces Plan to Close 4-Speed Transmission P | Charlie | General Saturn Discussion | 1 | 05-13-2008 08:49 AM |
Danger: High speed thread! Top speed on L300V6 and 2.2 -ecotec? | 2k3L300HID | L-Series General | 64 | 03-10-2005 11:53 PM |
