#1 |
![]() Join Date: Oct 2010
Greetings,
What issues would I open up, if in replacing a 02 3rd gen DOHC engine 5sp (with secondary air pump), to a 99 DOHC engine from a (non secondary air pump head)? Good Replacement engine has plastic intake, older style exhaust manifold (no enlarged can), came from automatic transmission car. both donor and 02 were cradle removed and easy access to work on engines. From what I have read, the secondary air pump affects at start , heating up cat sooner. alternatives: 1. is to swap heads on 99 engine to include the air pump add ons of 3rd gen head. 2. keep 99 DOHC replace ECU with gen 2? 3. other options? thanks found this link to similar 2nd gen to 3rd gen swap. https://forum.sixthsphere.com/articl...to-3rd-gen-car |
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2013
Can I assume you have no emissions testing? Otherwise, a fail of the visual inspection would kill this swap.
I'm thinking the secondary air is to help reduce NOX, not to heat the cat. Either way, it won't matter though if you have no emissions testing. |
#3 | |
![]() Quote:
being a '99 or newer head, it should be the roller-rocker type with 9-bolt exhaust manifold and provisions for the air injection system. in other words, the same head as the '02. take the exhaust manifold off the head and have a look at the ports. are there small round ports above the main exhaust ports? if so, you can simply swap the '02 exhaust manifold onto that head, along with the air pump, lines, and solenoid, and retain the system.
rings-1996 sl2 ~215k mi phoebe-1995 sl1 ~250k mi janus-2000 sohc2 ~190k mi tethys-1994 sw2 ~302k mi rip mimas-wrecked 1996 sw1-trailer pandora-1999 sc2 dione-1998 sw2 penny [iapetus]-1997 sw2 |
#4 |
billr - No emissions locally,
from the link at sixshpere "Other observations: The air system won't work with the older 5 bolt head.. but I'm not throwing a code for it on this car." gives me some hope of not sending a code to cause inspection failure. I will attempt to contact that individual to learn from them too. the 99 engine owner wanted to get the motor back from the car I was told by the JY owner when I bought it after the accident. I'll get pictures and check out exhaust ports tomorrow. thanks! |
#5 |
![]() ![]() Join Date: May 2004
I also think only 2 types head for 2gen and 3gen engines ... some at least of the '99 heads were mated with the gen2 aluminum InManifold. I believe all the
'99 heads had the ExMan with the precat & airpump (either Fed or CA emiss). The precat warms the downstream cat during first minute of operation following cold starts, it then relaxes (cools down), and provides some further oxidation of the exhaust stream during normal driving, while most of the work is performed by the downstream cat, which needs to be HOT in order to function. |
#6 |
nope, only ca (and ca-compliant states, whatever those were in '99-02) cars have it. janus is an '00 and it never had that system. pandora is a '99 and same thing, no precat or air. i've also seen a number of '01 and '02 cars at the jy without it. that said, it definitely is more prevalent on the 3rd gens than on prior years.
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2016
![]() Quote:
Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018 |
#8 |
No-air pump was a Fed vs Cali emission level thing '99-'00; standard '01-'02. Very complicated swap, no way anybody would just switch the manifold & downpipe to get rid of the stupid system on '01-'02s...
#9 |
Thanks to Ultravioletnk and Fetch for clarification comments !
@ swcoupe: The rear-mounted plastic InMan is major pain in neck to service, and they routinely Fail with mileage (possibly also with less/poor coolant maintenance). So, there is some advantage to earlier, aluminum manifold. However, it is very Rare that GM would redesign a cylinder head, And an InMan. Probably they had Good reason. I've seen three used heads for these cars. Two indicated perfect combustion -- uniform gray ExPorts. I Also think the plastic InManifolds May Be associated with much Less oil consumption -- these manifolds may have shorter, more equal length runners (or otherwise designed to decrease pumping pulses at highway speeds). >just a thought< Last edited by TomM96; 05-16-2022 at 11:04 AM. Reason: fergat un |
#10 | |
glad to help!
![]() Quote:
i believe the main motivation was to get away from the flat tappet lifter/cam design due to lowering levels of zddp in oil. the roller-rocker head does also run significantly quieter, and i know lowering nvh was a priority for the 3rd gen s-series. however, gm corporate really stabbed saturn in the back with the head redesign... for no apparent reason, they made the exhaust ports significantly smaller. the head design had potential to significantly increase power output, but instead they kept it at the same 124hp the dohc engine produced since its introduction in 1991. that makes the s-series one of the only cars not to see a power increase on the performance trim motor for a solid 11 years. it's one of many examples of how internal corporate feuds at gm screwed saturn over.
#11 |
At last got time to get back to this project.
The donor motor was not a 99 but a 2000! Removed the exhaust manifold and saw the ports for air pump. Am going to go back with the 2002 accessories. Am waiting on parts, rear main seal was seeping. I use carb cleaner to help clean out the carbon in the exhaust ports and air holes. Any suggestions for cleaning the air feed ports in the head? Should a wire be able to go through the hole? I use a small wire about the size of bailing wire, (used to tie rebar). This only went in about 1/4"- 3/8". |
Bookmarks |
Head/engine swap questions!! | saucybutton | S-Series Tech | 5 | 12-22-2014 01:15 PM |
coolant leak...head gasket, cracked head, or water pump? | BRIAN41920 | S-Series Tech | 13 | 01-11-2013 04:18 PM |
Head gasket or engine swap. | cinimod25 | Vue Tech | 2 | 01-02-2012 12:04 PM |
96 SC2 MT engine or head swap. | schellsquared | S-Series Tech | 4 | 05-07-2010 06:36 PM |
Can I swap a '98 head onto my '99 engine? | etothepii | S-Series Mods | 4 | 05-14-2009 01:07 PM |
