Old 05-03-2022, 03:53 PM   #1
hholbein
hholbein is just really nicehholbein is just really nicehholbein is just really nicehholbein is just really nice
1997 SW2
Default FSM picture of front brake caliper hose routing?
I recently had all my brake hoses replaced at a local shop as a preventative measure and now I noticed a grinding nose when I turn sharply left or right. I believe this is because the new hoses were installed 180 degrees out of the correct position with the loop facing the front vs. back. Does anyone have a picture from the Saturn FSM they could send me of the proper routing I can use to give the shop?
I'd like to have them correct the problem on their nickel.
Old 05-03-2022, 05:57 PM   #2
toggenburg
toggenburg's Avatar
Default Re: FSM picture of front brake caliper hose routing?
The brake line loop should be facing the rear of the car.
Old 05-03-2022, 06:20 PM   #3
hholbein
1997 SW2
Understood, but does anyone have a picture from the Saturn FSM I can send to the shop?
Old 05-03-2022, 07:15 PM   #4
Front gets looped to the rear, rear gets sent to the middle.
Old 05-03-2022, 07:46 PM   #5
hholbein
1997 SW2
Thanks a ton, fetchitfido, just what the doctor ordered!!!!
Hopefully I won't get any guff from the shop, but given how rarely I've had the car in the shop in the past 25 years, it's kinda sad to see such a mess-up. Most everything else I've done myself with the help from Old Nuc (RIP), RichPin, and others!
Oh well!
Old 05-04-2022, 04:38 PM   #6
trottida
trottida's Avatar
The caliper needs to come off and be rotated 360 degrees to make the brake line tuck in behind the strut rear facing.
1999 SL2 MT (299,400 km @ 11/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
I had to cut brake line at caliper hose... raymondjiii S-Series Tech 8 04-22-2018 09:43 AM
96 SC2 Hose routing issues theroadwarrior S-Series General 4 02-10-2018 06:42 PM
Front brake caliper rebuild help dddaaa S-Series Tech 13 09-14-2013 10:55 PM
Picture Request: Drivers side Brake Line to Caliper .kevin. S-Series Tech 14 08-02-2009 10:54 PM
Front Brake Caliper Replacement farescb S-Series Tech 6 07-31-2009 09:57 PM
