Old 05-21-2022, 11:52 AM   #1
SRGW
SRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to all
SRGW's Avatar
1997 SL1
Post Throttle body 1995 vs 1997 SL1
I have a spare TB with AIC and TPS from my 1995 SL1, can I use this on my 1997 SL1? Should I clean the 1997 one[dirty and idle hunting] or use the all ready clean 1995 one?
Thanks,
SRGW
1995 SL1 236,300 2005>2018
1997 SL1 97,000 2014>????
CHECK YOUR OIL!!
SRGW is online now   Reply With Quote
Old 05-21-2022, 12:49 PM   #2
billr
Default Re: Throttle body 1995 vs 1997 SL1
Pretty sure the '95 and '97 TBs are identical. I would try the already-clean one.
Old 05-21-2022, 01:12 PM   #3
Check the vacuum harness on top, it changes. Specifically they flip/flop which side of the throttle plate the big hose and little hose's are on. "Works" to swap the harness as well but there's a good engineering reason why they switched and it could be a bad idea to switch back.
I never remember which years went which way and it's an easy thing to check so I probably won't remember even if I get told yet again
Old 05-28-2022, 10:41 PM   #4
SRGW
SRGW's Avatar
1997 SL1
Post Re: Throttle body 1995 vs 1997 SL1
Just for your info top vacuum harness is different. Wound up cleaning original and it was very dirty!! So far no more idle hunting.
CHECK YOUR OIL!!
1997 Saturn broke hose on top of Throttle body lolobree S-Series Tech 6 02-02-2015 08:17 AM
03 L300 no start unless the throttle motor/ throttle body unpluged Woody117 L-Series Tech 2 12-25-2012 07:33 PM
1997 Saturn SL1 Throttle Body Questions ... OpalesceNyx S-Series Tech 5 04-20-2011 10:54 AM
Help me find a 1995 SC1 throttle body spacer! Dreamimage S-Series Mods 4 07-27-2007 11:26 AM
[guide] 1995 SC2 Throttle body cleaning w/ PICTURES delturcious S-Series Tech 3 06-23-2006 10:45 AM
