![]() Join Date: Apr 2022
1999 SW1
I was looking at these PF5501 fuel filters and was wondering if anybody had tested them? Or is the Baldwin BF9851 the only quality one out there now? It seems the NAPA and WIX are no longer available. It's for 1999 SW1.
#2 | |
rings-1996 sl2 ~215k mi phoebe-1995 sl1 ~250k mi janus-2000 sohc2 ~190k mi tethys-1994 sw2 ~302k mi rip mimas-wrecked 1996 sw1-trailer pandora-1999 sc2 dione-1998 sw2 penny [iapetus]-1997 sw2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2016
I think the important thing is the kwality of the built in fuel pressure regulator.
Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018 |
right, the returnless system integrates that into the fuel filter... i like the return-based system better, personally.
#5 |
Everyone with an S-Series likes the return system better. Last I knew the parts store wanted $25 for the "officially fits" filter for '91-'97's but there is a under $10 filter for a Ranger (don't remember if it's a 4cyl or 6cyl) that swaps on with little to no effort.
If WIX isn't making the filter for '98-'02 anymore you'll have to try your luck. Maybe invest in a fuel pressure gauge, off the top of my head it should be 45 psi +/-5 while the earlier ones were 40psi +/-5. |
1999 SW1
So the return style is the one with the extra inlet? The only variable is the media it's made of? I know they switched the fuel filter in 1998...did the previous years not have the extra inlet?
#7 | |
and yes, the only two variables of any consequence are the fuel pressure regulator built into the filter (probably not too likely to drastically vary in quality) and the media. i wouldn't worry about it too much, it is easy to swap the filter if for some reason you aren't satisfied but there's just not too much to go wrong. i've cut open a fuel filter before and it's just paper media, somewhat like a coffee filter but thicker/more rigid.
#8 |
It's not the filter media that goes wrong on the "not WIX" '98+ filters, it's the FPR. It's rather like Dex 3 vs Dex 6...lots of cars get away with using the "compatible" fluid but the S-Series gets very angry.
#9 |
i don't know what brand fuel filter i have on janus, but i'm almost positive it's not wix. it was the cheapest one on rockauto at the time. i installed it years ago and it's still going strong, no issues whatsoever to speak of.
#10 |
I just put in a new fuel filter. I had a gas smell if I ran my car for more than 15-20 minutes or so. It was very noticeable when I parked it in our garage. I could not find a gas leak. I had the filter already, so I figured I'd put it in and it That fixed the gas smell. Disconnecting the two gas connections was a bit of a pain IMO. Much easier putting it back in though.
96 SW2 5MT |
#11 |
1999 SW1
What brand of fuel filter did you install? Is it running good? Any mileage change?
#12 |
It is a Baldwin from Rockauto.
96 SW2 5MT |
#13 |
'91-'97 cars use a fuel filter. '98-'02 cars use a fuel filter + pressure regulator combo.
'97 and earlier can use whatever filter you can attach to the lines that flows the required amount of fuel. OEM style connectors not required if you're a bit innovative. '98 and newer you have to use OEM quality filter (WIX was the proven aftermarket brand in the past) or you fairly often end up with pressure issues. If WIX isn't an option anymore then you may have to change the filter/regulator more often. |
#14 |
at least the combo filter/regulator units have gone down in price, i remember when it was $120 for a wix one! with that kind of price, i didn't think it was worth it for a fuel filter on janus.... i'm still running the same filter i put on 5 years ago, whatever brand it was, with no issues.
#15 |
1999 SW1
If anyone has done an OEM style filter change on a 98+ year saturn S-Series please let us know where you got it and the brand. We seem to need a WIX replacement going forward. Lots of false advertising/made in China X%5XZ# out there online!
#16 |
unfortunately, like most things these days, nearly all the available aftermarket parts on the market now are made in china. you can blame economic pressures and large companies preferring to outsource rather than support local economies for that. i seem to be in the minority here, but while i don't like that it's nearly impossible to find new replacement parts actually manufactured on the continent of north america, i haven't had any quality issues with most of the chinese parts. i've put "ultra-power" suspension parts on multiple of my cars, and i tend to buy the cheapest option for things like fuel filters, and i've had no issues. sensors and active engine management components like the iacv and egr, however, are a different story. with those oem seems to be the only worthwhile option.
#17 |
![]() ![]() Join Date: May 2004
I just went though this issue again a couple weeks ago... to the tune of
two 6-hour search & procure missions...... See the summary of the discussion including OldNuc from a decade ago: http://www.saturnfans.com/forums/sho...d.php?t=176979 o- 02-10-2012 #1 gosaturngo Default which napa fuel filter to buy??? FIL 3731, which is direct replacement for 98 sl2 but cost almost 80 bucks or FIL 3100, which is about 50. I saw a thread about using this one. Looking at the specs though the two filters have the same fitting sizes and all but ones a little bigger than the other by 5mm or so. >>>> o- 02-10-2012, #2 OldNuc Use the FIL3731 only. o- 02-10-2012 #3 ssewall Join Date: Jun 2011 Location: Maine Posts: 1,088 The 98+ S-Series has the fuel pressure regulator built in to the filter, which is why it's so expensive. The cheap ones are notorious for low FP issues, which can lead to expensive repairs. Don't skimp on Fuel Filters for 98+ models. o- 02-11-2012 magtec → if you like burned exhaust valves get the cheap filter. o- 02-11-2012 #5 rbar Location: Tennessee Why? It makes it run too lean? I thought the oxy sensors would adjust the mixture for some variation there...perhaps it would be too much variation to handle? o- Old 02-11-2012 #6 OldNuc Yes, you just run out of fuel and that is the end of it. At higher RPM/road speed the O2 sensor is completely bypassed anyway. …................................................. .... :: Current listing :: PartsGeek – fuel filters April 2002 → K&N Fuel Filter Part Number: 4904-02854089 Manufacturer Part Number: PF-2400 $22 0stock → Hastings Fuel Filter Part Number: 4904-05041681 $54.15 Out of Stock → Baldwin Fuel Filter Part Number: 4904-06085573 OE Number : 21009427 $60.33 Also: 'Pronto' & 'Premium Guard' filters listed, $36 , $26 ea …................................................. ... Erroneous Amazon listing/advice: https://www.amazon.com/PF5501-2000-0.../dp/B001KR6I62 Premium Guard PG Fuel Filter PF5501 | Fits 2000-03 Chevrolet S10, 2000-03 GMC Sonoma,{2.2L} 1998-01 Saturn SW2, 1998-02 SC1, SC2, SL, SL1, SL2, 1998-99 SW1 $32.30 I SUSPECT/BELIEVE that the Wix 3100 (which serves V-6 GM) probably has a pressure-following-response Too Slow to keep our 1.9 engines happy. There are several posts about cheaper filters causing fuel starvation (burnt valves). * * Another Erroneous Amazon listing: https://www.amazon.com/s?k=mahle+fue...r&i=automotive Purolator F65501 Fuel Filter $34.95 Brand – Purolator Product Grade Performance Part Manufacturer Part Number F65501 ASIN B000C6OLF2 I later spoke to a supplier/importer/distributor, who confirmed that the Purolator F65501 was comparable to the Wix 3100, not the required 3731 ...................... ...................... I strongly advise to buy from Rock Auto, the Baldwin/Hastings unit. I believe that Hastings was acquired by Baldwin. Soooo: RockAuto Fuel Filter HASTINGS / BALDWIN GF380 {#21009427, BF9851} $44- .................................................. ... .................................................. ... I became weak... /sole supplier blues/ I investigated another source, which specializes in Chinese imports But first, another listing to AVOID: https://www.amazon.com/ECOGARD-XF655.../dp/B00I8J30ZM ECOGARD XF65501 Premium Fuel Filter $40.47 Fits Chevrolet S10 2.2L 2000-2003 | GMC Sonoma 2.2L 2000-2003 REPLACES ACDELCO GF845, FRAM G9370, GM 12476276, 15036706, 15077584, PUROLATOR F65501, WIX 33100 .................................................. ............... .................................................. ............... Again, I suggest the Baldwin Hastings from Rock -- BF9851 ...................................... ...................................... ...................................... My optional/second source for gen3 fuel filter/regulator: https://ipcglobalsolutions.com IPC Global Solutions, headquartered in Taunton, MA is a leader in the private label filter business. https://www.ecogard.com/oil-filter-l...earch-catalog/ for: 2000SL2... Ecogard - Part Number: XF11668 Part Type: Fuel Filter cost around $40. Were out-of-stock a couple weeks ago, but (friendly folks) they were/are on order, should be available soon. I think Walmart and Amazon will carry them soon (sure Walmart, maybe Amazon). |
#18 | ||
![]() Have I got a deal for you - GK Industries Part number: GF1846. http://www.saturnfans.com/forums/sho...d.php?t=137296 Quote:
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#19 |
Fine job (once again), Chaos!
The interchange listing suggests that GKI may supply some other retailers (See * *): http://gkindustries.com/ http://www.gkindustries.com/76/about-us http://gkindustries.com/en/127/oil-filters http://gkindustries.com/en/133/synthetic-oil-filters http://gkindustries.com/en/126/transmission-filters http://gkindustries.com/en/128/fuel-filters http://gkindustries.com/en/132/bulletins https://gki.mypartfinder.com/ FuelFilter GF1846 With OE adapter Micron Rating: 14 Inline primary fuel filter; inlet O.D. 0.38”; outlet O.D. 0.31”; Material-SS; with mounting bracket INTERCHANGE FF897DL........................................Aut ozone 61633931........................................Au toXtra BF9851...........................................B aldwin R86731...........................................C arquest Red G6628............................................. Champ 023-3680-8.....................................Canadian Tire GF380............................................F ederated GF1846..........................................Fe derated * * 21009427.......................................Gen eralMotors 21008344.......................................Gen eralMotors GF1846..........................................GK Industries * * GF380............................................H astings G6628............................................L uberfiner GF1846..........................................NA PA ProSelect * * 22035061.......................................Omn iparts Automotive 73931............................................. PARTSMASTER 6-33931........................................Purez one 33731............................................W ix * * * I agree with Waiex191, and Fetch, that the FPR kwality is Kritical. The filter media may also be important, however... our engines constantly circulate fuel through the fuel pump. Thus better filtration means Cleaner fuel, and less Wear on injectors and fuel pump. I once bought filters partly based on price/convenience. Then, i did an oil+filter change on a trusty old Chevy 350, which immediately developed a notable 'rod knock'. A friend suggested that I swap in another filter for the newly-installed (Fram) cartridge. Problem Solved! Fram is sold universally here on L.I., possibly because their headquarters is/(was?) in nearby Connecticut. That was about 40 years ago, but it got my attention. Among diesel drivers, much discussion of the fuel filter medium occurs. I believe the concern is injector wear (much higher pressure, but that fuel is also a much better lubricant) and FuelInjectionPump wear. The GKI filter is rated '14 micron', which I think is respectable, although some guys like a 10micron rating. One source described the essential difference between home heating fuel oil, and diesel fuel, is Refinement: The diesel has mandated very Low sulfer, and very, very low particulates. .................................................. ............................................... |
#20 |
1999 SW1
TomM96...Thanks, for all the work on listing fuel filters for 98-99 Saturns. This is what I enjoy most about this forum!
I might give the 023-3680-8...Canadian Tire one a go. Again, much appreciated on your thoughtful response. |
Is premium fuel the answer? | Ramics | S-Series Tech | 23 | 05-24-2012 07:11 PM |
760km/Tank so far, what if I use Premium Fuel? | HalifaxHybrid | Vue Green Line | 8 | 07-09-2008 10:57 AM |
Premium fuel in 2.4L? | cdavidhess | Ion General | 60 | 07-05-2006 01:49 PM |
Looking for GOOD pic of grill guard | 20VUE06 | Vue General | 0 | 03-10-2004 11:24 PM |
Premium Fuel ? | bob shanks | Vue General | 3 | 06-26-2003 07:30 PM |
