Old 03-12-2006, 01:17 PM   #1
vjgkam
vjgkam is on a distinguished road
Question Sirius radio and hardwired FM
I have a plug and play Sirius radio in my '02 L300. I am currently using the FM modulator in the unit. I travel into New York and Philadelphia a lot, and there are absolutley no free FM stations, and the FM broadcasts take over the Sirius signal.
I wwant to install the hardwired FM antenna, but would like to know how to get to the back of the radio.
Can anyone help??
Thanks!
vjgkam is offline   Reply With Quote
Old 03-12-2006, 01:37 PM   #2
silverblueL200
silverblueL200 is on a distinguished road
silverblueL200's Avatar
Default Re: Sirius radio and hardwired FM
Getting the radio out is pretty easy. Push the top vents down and the pull outward from the bottom of the vents, its easiest to just push it over to the side with the wiring harness still attached. The radio then comes with two simple screws on either side.
- 2003 Saab 9-3 Arc
Hello, mother. I come bearing a gift. I'll give you a hint. It's in my diaper and it's not a toaster. -Stewie Griffin
silverblueL200 is offline   Reply With Quote
Old 03-12-2006, 01:44 PM   #3
vjgkam
Thanks!
I'll give it a whirl!
Old 03-13-2006, 09:35 AM   #4
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
He's right. It is fairly easy to do. I just installed an FM modulator in my L, Friday. With the help of my son, it took us at the most, a half an hour.
The trick is get that bezel to pop out. Just gently push on it's sides, then carefully pry it from the dash.After that, unhook the switches from it. Use a 7mm socket to pull the radio out from the dash. DON'T pull the wiring harness out unless you have to. (you will have reset the code, time and stations if you do).
I don't know about Siruis, but the modulator works great for XM. I had the same problem trying to find an open frequency without it. Now it works like a charm.
Thanx again to DJ (OhioVueBoy) and AnotherSaturn for your help.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
unkle bik is offline   Reply With Quote
Old 03-16-2006, 12:44 PM   #5
Bigwallyz
Bigwallyz is on a distinguished road
Bigwallyz's Avatar
Dizzy Re: Sirius radio and hardwired FM
I ordered a Sirius S50 for my car and awaiting for it to arrive anyday now so I can listen to Howard.
Owner of www.MilitaryTuners.com
Come and check it out if you are in the Military or have ever served at one time.
Bigwallyz is offline   Reply With Quote
Old 03-19-2006, 05:03 PM   #6
vjgkam
I was amazed how easy it was to nstall the hardwired FM.
One thing though: I now hear engine noise (whining) over the speakers...any ideas?
Old 03-19-2006, 06:59 PM   #7
frostypanic
frostypanic is on a distinguished road
frostypanic's Avatar
2003 L-Series 2.2L Sedan
Cool Re: Sirius radio and hardwired FM
Big Walyz,
I'm loving Horward now that he is on Sirius, I actually never was able to listen to his show, me being in the Bible Belt. I have been drooling over the S 50 ever since they came out with one. Let us know how you like it, from what I understand it does everything an I-pod does plus sirius. Uncle Bik, how much did that FM modulator set you back.
Brian
frostypanic is offline   Reply With Quote
Old 03-20-2006, 09:25 AM   #8
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
FM modualtor = $29
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 03-20-2006, 07:26 PM   #9
silverblueL200
Did you check all your grounds and make sure the modulator wire is kinked in anything?
- 2003 Saab 9-3 Arc
Old 03-21-2006, 02:19 PM   #10
SiriusVue
SiriusVue is on a distinguished road
SiriusVue's Avatar
You will love it. The built in FM modulator in the S50 is pretty strong compared to other units.
Do your self a favor. When you get your new S50, open it, power it up and activate it online. www.sirius.com Once activated, plug the S50 into your computer and download the latest (and greatest) update.
Update the unit before adding content. It may be erased when updated.
Feel free to check out www.siriusbackstage.com for some cool Sirius Chat.
Enjoy!
SiriusVue is offline   Reply With Quote
Sirius radio FM interface with car radio firefox23508 Vue General 0 04-11-2007 01:48 PM
Sirius Radio 10W30 S-Series Mods 9 08-28-2006 04:54 PM
Sirius radio anyone? ric_oro L-Series General 2 05-30-2006 11:11 AM
sirius radio battlema Vue General 0 04-04-2006 12:28 PM
sirius radio CRAZYENGEL Ion General 14 07-22-2005 10:26 AM
