Old 08-29-2017, 08:30 PM   #1
Jamesormand
Jamesormand is on a distinguished road
Default 2005 saturn vue no spark condition. Replaced icm spark plugs cps
I have a 2005 saturn vue which just recently had a motor put in it. I have checked all related fuses and relays. Replaced icm spark plugs and CPS. Still I am not getting any spark. Does anyone have any idea what is going on.
Jamesormand is offline   Reply With Quote
Old 08-29-2017, 09:25 PM   #2
Default Re: 2005 saturn vue no spark condition. Replaced icm spark plugs cps
1-Is security (Passlock) flashing quickly with ignition ON and while starting? Passlock flashing means its enabled and actively disabling injector operation as part of factory theft deterrent protection. Security normally cycles on and off during starting.
2-A simple and quick test for fuel or spark failure is to spray staring fluid into the throttle body and startup. Either the engine starts up (indicating a fuel issue) or not (indicating an ignition issue).
3-At ignition on time, the fuel pump runs for two seconds then shuts off but long enough to generate pressure. Removing the fuel test valve cap and depressing the valve stem should have fuel spray out with force (use a rag to catch fuel). Normal pressures are between 50-60 psi. This checks for fuel and pressure, not injector operation.
Old 08-29-2017, 10:45 PM   #3
atikovi
Shouldn't the place that put the motor in be the ones figuring this out?
Old 08-30-2017, 02:07 AM   #4
Judogi
Judogi is on a distinguished road
2001 SC1
Was it running after the swap and then suddenly quit? Or has it never run after the swap? Like the poster above stated, listen for the fuel pump.
Judogi is offline   Reply With Quote
Old 08-30-2017, 06:51 PM   #5
Jamesormand
It's getting fuel. Replaced cps, icm, and all related fuses. It just no spark. Passlock is not active and motor did work before. It came out of a saturn ion. 2005.
Old 08-30-2017, 07:35 PM   #6
waiter21
2003 VUE 2.2L
Did it ever work in this car after the swap???
Old 08-31-2017, 10:26 PM   #7
ruley73
ruley73's Avatar
Make sure you have a good ground connection between the engine and the chassis. Check your engine wiring harness (more specifically the wiring going to the coil pack and ICM) for damage.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles *gone*
2007 Chevy Equinox LT 205K miles
2018 Chrysler Pacifica Touring L 74K miles
Considering replacing spark plugs and spark plug wires - Need advice 2002SaturnMan S-Series Tech 25 10-15-2015 08:29 AM
SL2 engine problems after valve cover gasket, spark plugs and plug wires replaced jfmock350 S-Series Tech 0 09-17-2012 12:39 PM
replaced spark plugs now cylinders misfire BGroth S-Series Tech 1 10-31-2009 01:34 PM
Replaced EGR Valve/Spark Plugs 2NDSOUT S-Series Tech 1 05-24-2008 05:26 PM
Replaced the spark plugs S Keith Vue General 20 01-12-2005 12:01 AM
